Author Topic: Fitting a GTI steering Wheel  (Read 17339 times)
Offline jonm
    • Staffs-VW
« on: November 09, 2011, 12:19:34 pm »
Got my hands on a gti wheel now, but before i pull the airbag off is there anything I should be aware of when doing this task?
Also what size if the nut holding the wheel on...
Offline dodds-gttdi
  • -Given: 22
  • Edinburgh
Re: Fitting a GTI steering Wheel
« Reply #1 on: November 09, 2011, 01:21:20 pm »
I'm in the same boat, mate. Got my GTI steering wheel but not fitted yet. Here's all the necessary steps as far as I can work out:
1. You need to turn the steering wheel (in your car) 90 degrees left and un-hook the clip at the back that holds on the airbag.
2. Then turn the steering wheel right 180 degrees and un-hook the other clip.
You should see where these two (exposed) metal tabs are for the airbag to latch onto on your yet-to-be-fitted steering wheel.
You will probably need a stubby but not too chunky flat screw driver to get into it.
4. Once you have the airbag unclipped, return the steering wheel to straight/centre/forward then disconnect the battery so nothing explodes when you unplug the airbag from the steering wheel. I think this also prevents any airbag warning lights coming on.
5. The nut in the centre is a spline M12 not a Torx bolt. You can get M12 Spline Sockets from ebay for fairly cheap.
6. As I haven't actually carried any of this out yet, I guess the next step will be to undo the bolt, and mark up the top of the spline shaft so you can align up your next steering wheel. I don't know if it is possible to put the steering wheel on squint or if there is a master spline so it can only go on one way.
7. once you have the new steering wheel on, put the central bolt back on and torque to 50NM (so I'm told), plug back in the airbag and clip it back in place.
8. Re-connect your battery or you won't get anywhere fast.  :wink:
This is all info I've gathered on forums, etc and not advise given from experience. Let me know how you get on. Cheers  :happy2:
Offline skard
  • -Receive: 245
« Reply #2 on: November 09, 2011, 01:46:56 pm »
When I disconnect the battery to remove the wheel, I leave it a good 10-15 minutes before taking the airbag off.
I'm sure I read somewhere about pumping the brake pedal to discharge the electrical system?
Once you've put it all back together, chances are your ESP and ABS lights will be illuminated. With the engine running, turn the steering wheel fully in both directions and drive slowly in a straight line. The dash warning lights should go off.
Offline jonm
    • Staffs-VW
« Reply #3 on: November 09, 2011, 02:30:26 pm »
thanks for the info  :happy2:
Offline vRS_Pagey
  • -Receive: 59
« Reply #4 on: November 09, 2011, 03:47:10 pm »
You only need to remove the negative side of the battery, and leave it for 2 minutes.  I fitted a cruise control today which required steering wheel removal, job was completed in under 15 minutes.
Offline dodds-gttdi
  • -Given: 22
  • Edinburgh
« Reply #5 on: November 09, 2011, 03:58:25 pm »
Any tips for getting the airbag off, i.e. perfect tool/screwdriver?
Also did you leave the battery connected until after you had unclipped the airbag or disconnect it before you started? Just wondering as turning the steering wheel with no power steering is gonna be a mission I'd imagine.  :stupid:
« Reply #6 on: November 09, 2011, 04:07:16 pm »
Short fat flat bladed one works perfectly
Offline vRS_Pagey
  • -Receive: 59
« Reply #7 on: November 09, 2011, 04:20:15 pm »
I used this guide - http://www.sciroccocentral.co.uk/roccopedia/index.php?title=Fit_Cruise_Control - As I was trained by Thatcham I stick to the H&S rules so disconnect the battery first before going anywhere near the airbag, tbh it's not that hard to move the wheel, but it will probably be perfectly safe to pop the clicks to the release the airbag prior to disconnecting the battery but I wouldn't recommend it.  :happy2:
« Last Edit: November 09, 2011, 07:52:45 pm by vRS_Pagey »
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #8 on: November 09, 2011, 07:23:29 pm »
Apart from disconnecting the battery BEFORE commencing work on removing the airbag. it is a good idea to ground yourself (discharge any static electricity)
Cluster and Key coding
Location Great Yarmouth
Offline mortygttdi
  • -Receive: 146
« Reply #9 on: November 10, 2011, 02:53:01 am »
I know its in the big rule book of h&s but to this day i have never ever seen an airbag go off by accident? Touches a very big piece of wood :innocent: you can twist the wires together on the airbag loom it will not go off it would only trigger a fault in the system, now i'm no pyrotechnic engineer but imo as long has the battery neg lead is disconnected your not going to get any nasty exploding bags in your face, i'm not saying jump in feet first? But don't be scared of the airbag. Famous last words over have fun get it done and enjoy your modding...
Darren
Offline vRS_Pagey
  • -Receive: 59
« Reply #10 on: November 10, 2011, 08:45:09 am »
In my job we are trained by Thatcham to search vehicles, mainly because of the need to remove SRS equipment and fuel systems, during the training they deploy an airbag, needless to say it is an impressive sight.  But as Darren says, in all my years I have never seen an airbag deploy accidently, however there is always a first time.
On 99% of newer car the removal of the negative side is all that is required and most need 2 minutes discharge time, iirc the maximum requirement is 15 minutes from some Mercedes.  Best practice for the untrained would be to completely disconnect the battery, then go and make a cuppa!
If anyone needs it, I have access to Thatcham.net which will give methods for all current SRS systems, including torque settings for refitting the airbag (not applicable on the Golf) and steering wheel.   :drinking:
Offline Johnny_tro
« Reply #11 on: November 12, 2011, 10:42:10 pm »
Lame question (maybe) but when I have done any work (incl) airbag I have ALWAYS pulled the poss (+) lead from the battery. Is this completely wrong? should it always be the neg (-) ?
Kinda thought so long as ones off it will do the same job?
'VANDALISED' MK5 GT :( - RNS510 H, Bluetooth Armrest, MDI, 50gb hard drive, I can't park  sensors, Cruise Control, Highline Display, MFSW, Heated Seats, Remote Aux Heating System (Heats and Vents) Winter Pack, Heated & Folding Mirrors, Puddle Lights, Xenons, Headlamp Washers, Heated Washers, Auto lights and wipers, LED's, GTI brakes,, black R32 roof lining, Scirocco Rear View, Rear Footwell Lights
Offline jonm
    • Staffs-VW
« Reply #12 on: November 16, 2011, 01:24:58 pm »
less than 5mins and it was done....
Pulled off the - neg terminal
turned steering wheel right undid clip
turned steering wheel left undid clip
pulled airbag out and unplugged
removed big nut
pulled wheel off
put wheel on
tightened big nut
plugged airbag back in
pushed airbag back in
replaced battery terminal
Job Done
Offline ali6n2
« Reply #13 on: November 16, 2011, 04:38:13 pm »
is it a must to get the torque setting right when screwing the spline back in?
Offline vRS_Pagey
  • -Receive: 59
« Reply #14 on: November 16, 2011, 06:41:25 pm »
Negative only or both mate.
removed big nut
pulled wheel off
put wheel on
tightened big nut
Job Done
It took that long....... :P
I would.
« Last Edit: November 17, 2011, 09:47:21 am by vRS_Pagey »
