Author Topic: LED Bulbs?  (Read 15203 times)
Re: LED Bulbs?
« Reply #30 on: April 28, 2009, 09:06:56 pm »
Looking much sharper :happy2:
Does this mean you are going to drive with your sidelights on, using them as DRL's?
Offline SteveP
  • -Given: 117
  • -Receive: 341
    • My Project
Re: LED Bulbs?
« Reply #31 on: April 28, 2009, 09:08:48 pm »
Maybe, If at the next meeting a friendly VAG COM person is about I might give it a try  :happy2:
The pic's don't do it justice, now it's dark they look much cleaner and brighter.
Re: LED Bulbs?
« Reply #32 on: April 28, 2009, 09:32:24 pm »
Good idea, but I'm an enthusiastic believer in LED DRL's :happy2:
Offline SteveP
  • -Given: 117
  • -Receive: 341
    • My Project
Re: LED Bulbs?
« Reply #33 on: April 28, 2009, 09:36:51 pm »
^^^ Really Robin I hadn't noticed  :wink:  :laugh: :laugh: :laugh:
Re: LED Bulbs?
« Reply #34 on: April 29, 2009, 11:43:50 am »
what resistor did you use steve? 100 ohm?
« Last Edit: April 29, 2009, 12:22:32 pm by JPC »
Offline bennylenny88
  • needs moar lowwww
Re: LED Bulbs?
« Reply #35 on: April 29, 2009, 11:55:55 am »
my dads roc came standard with led sidelights :S
Offline animal
  • .:R32
Re: LED Bulbs?
« Reply #36 on: April 29, 2009, 12:05:01 pm »
As standard or as an option?
Are they standard W5W wedge fitting - i.e. VW OE LED bulbs in the existing bulb holders or are they a more permanent part of the headlight?
I've notice LED side lights are an option on E Class Mercs now and have been trying to find out if the fit straight into the existing bulb holders or if they are hard wired.
  • needs moar lowwww
Re: LED Bulbs?
« Reply #37 on: April 29, 2009, 12:58:08 pm »
standard mate. theyre not in the headlights mate theyre on the strip near the bottom next to the indicators.. its a GT model though..
Re: LED Bulbs?
« Reply #38 on: April 29, 2009, 05:37:42 pm »
just tried with 2w 100ohm resistors, they work fine. the LEDs i use dont get hot at all, but the resistor does, so im going to locate that somewhere along the loom rather than squeeze it all in the bulb housing.
Offline SteveP
  • -Given: 117
  • -Receive: 341
    • My Project
Re: LED Bulbs?
« Reply #39 on: May 02, 2009, 09:31:19 pm »
^^^ JPC, are the resistor's in Aluminum housings???
Here my next LED conversion, puddle lights  :smiley:
BEFORE: -
AFTER: -
In the twilight there aren't quite as bright as the stock yellow bulbs but once it's properly dark they look great  :happy2:
And the other plus there is no bulb check on puddle lights so no need for resistors  :drinking:
Re: LED Bulbs?
« Reply #40 on: May 02, 2009, 09:40:57 pm »
So it's just a matter of changing the bulbs.
And where did you get the bulbs please?
Offline SteveP
  • -Given: 117
  • -Receive: 341
    • My Project
Re: LED Bulbs?
« Reply #41 on: May 02, 2009, 09:46:44 pm »
Yes on the puddle lights is just a bulb change, all you need is a small torx/star screwdriver, takes about 1 min to do  :happy2:
The ones I have are the 6 LED version here - http://www.autobulbsdirect.co.uk/501-6-led-bulbs-c-611-p-1-pr-17741.html
You can get them cheaper (from the place you don't like) but these are good quality IMHO  :drinking:
Re: LED Bulbs?
« Reply #42 on: May 02, 2009, 09:55:50 pm »
Cheers! [I daren't Thank You!!] :drinking:
I'd much rather go for quality than price. There's quite a few places I don't like, aren't there? :evilgrin:
Oooh! I've just checked the link - I could have some blue ones! :jumpmove: :jumpmove:
« Last Edit: May 02, 2009, 10:12:10 pm by RedRobin »
Re: LED Bulbs?
« Reply #43 on: May 05, 2009, 08:43:57 pm »
BEFORE: -
AFTER: -
there Metal Film Resistors. good for 500v and 2w.
puddle lights looking brilliant, sir! ;)
Offline nick-barnes07
Re: LED Bulbs?
« Reply #44 on: June 08, 2009, 08:56:08 pm »
i put a set of led side light bulbs in my golf earlier on and they are also doing the same, anyone find a way to get around this, have u got to put a resistor in with them, or is that the puddle lights on mirrors???
