Author Topic: Painting Brake Discs  (Read 9908 times)
Offline jimk04
Re: Painting Brake Discs
« Reply #15 on: March 09, 2012, 05:06:54 pm »
If you look on my 330mm brake conversion thread in Performance Mods - you will see a brake disc in zinc primer - then in VHT aluminium later on with the masking removed. Quite easy to mask....put tape all over the friction surface - overlapping inner and outer edges.
Then with a real sharp knife  - working away from you - trim off the tape a bit like trimming the pastry off a pie! The inner one just follow the recess as best you can.
Milltek tbe, Forge intercooler, AMD map, Eibach Sportlines, Porsche 996 over AMG 330mm homegrown BBK
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #16 on: March 09, 2012, 05:34:10 pm »
With the NQSBBK you also need to paint 10mm of the disc surface. Not as easy to mask. All sorted now anyway. :) looks sh*t until the pads wear the small extra bit of paint off.
#1493
Offline Kalpsn2000
  • -Receive: 56
« Reply #17 on: March 09, 2012, 09:32:17 pm »
Anyone got pics of their painted discs?
Offline vRS_Pagey
  • -Receive: 59
« Reply #18 on: March 09, 2012, 10:39:23 pm »
Offline Syrag64
« Reply #19 on: March 09, 2012, 10:46:25 pm »
I painted mine with some matt black paint (not even VHT) seem to be holding up well, look much better than rust!
If the paint fails i'll be stick some hammerite on them  :signLOL:
Black 2007 GTI Manual, Stage 3 K04, R32 Bumper/Exhaust, WALK, adj rear ARB, KW1's, Twintercooler, Twintake, 18's (winters), 19's (summer) modified dectane LED rear lights, NQSBBK, Forge dump valve, Xenon look headlights with 5000k HID, 3" downpipe with sports cat, TT wishbones, uprated HPFP, Sach Uprated Clutch, Quaife LSD, VT & THS Engine Mounts.
To be fitted: Reverse Camera & uprated headunit.
Future plans: De-dent & Detail
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #20 on: March 10, 2012, 10:26:03 pm »
Well, they look perfect now. Paint on disk surface nicely worn down, perfect edge. Really pleased with how it looks. Might need a touch up from time to time.
#1493
Offline Syrag64
« Reply #21 on: March 10, 2012, 10:40:51 pm »
Same as mine :evilgrin: i'm surprised really because the paint I used isn't VHT and i've done some very spirited driving and the paint is holding up well!  :happy2:
Offline the bruce
  • -Given: 322
  • -Receive: 101
    • my GTI
« Reply #22 on: March 11, 2012, 02:33:17 am »
DupliColor Supertherm 800° C:
"You get what you pay for."
Offline vRS_Pagey
  • -Receive: 59
« Reply #23 on: March 11, 2012, 06:46:02 pm »
 :drool: :drool:  :notworthy:
« Reply #24 on: April 02, 2012, 05:56:20 pm »
Luke, i just bought some OEM discs from VW and they are sprayed silver all over.  :happy2:
Offline the bruce
  • -Given: 322
  • -Receive: 101
    • my GTI
« Reply #26 on: April 02, 2012, 07:26:31 pm »
^^^  :signLOL:
Offline alexperkins
  • -Receive: 99
« Reply #27 on: April 08, 2012, 03:08:28 pm »
Its not paint as such. Its more of a zinc based anti corrosion finish  :wink:
