Author Topic: K04 conversion bits and pieces, Please help guys!  (Read 6416 times)
Offline Sammy
« on: May 08, 2012, 04:06:32 pm »
I am just about to do the k03s to k04 conversion, So far i have managed to get the parts for it through VRS Alex, Below are pics of what i have but i just want to be certain this is it all because the last thing i want is my car stripped down and then the need for more parts!
Alex has said this is all il need to do the conversion including the S3 injector upgrade and diverter relocation, Anyone who knows about this stuff help would be greatly appreciated, Thanks  :happy2:
This is the pic that has everything in it just not sure what is nessacary really:
« Last Edit: May 08, 2012, 04:14:05 pm by Sammy »
GTI MK5 with all the gooodies
K04 power going on soon!
Offline Sammy
Re: K04 conversion bits and pieces, Please help guys!
« Reply #1 on: May 08, 2012, 04:12:19 pm »
Forgot to add i also have the discharge pipe, The parts i have doubts on are the k03s and k04 oil lines can they be re used from my k03s?
For the diverter custom wiring i am told that it can be extended and brought up to the front instead of making a custom wiring for it is this do able also?
« Last Edit: May 08, 2012, 04:15:46 pm by Sammy »
Offline bacillus
  • -Receive: 453
« Reply #2 on: May 08, 2012, 04:23:59 pm »
Does your present intake have a port to connect the relocated DV?
I believe most folk use an extended wireing harness so that there is slack in the wireing.
Offline Sammy
« Reply #3 on: May 08, 2012, 04:43:08 pm »
Yes it does so that i dont have to worry about mate, I just want to know if the original DV wire can be used with it
Offline Sie
« Reply #4 on: May 08, 2012, 07:13:45 pm »
From what I gathered, you have to remove the plug off the end strip apart the harness then pull it back sounds like a lot of hard work to me, I plan to just a dv vacuum dv like the forge fed off the end of the intake plenum.
Can be done yes.
Sie
Fettled Laser Blue '05 GTi 5dr
Offline Sammy
« Reply #5 on: May 08, 2012, 08:26:21 pm »
Thanks anyone elsee with more info? Someone must know!
Offline martziniuk
« Reply #6 on: May 08, 2012, 09:05:28 pm »
I know what's needed as I fitted mine myself.
You need water and oil line crush washers also the clips for the dv relocation flange (unless you use jubilee clips)
2x m6 nuts to hold the dv bracket to the intake manifold. I presume you've got the fitting kit to go with the injectors? A dv harness is required, as I've said before there is no way the original wire will reach DV, it's about 1.5ft short.
I can't think of anything else at the minute.
Mk2 Octavia vRS with K04 conversion, 3"TBE & Decat, APR HPFP, BDM Intake, S3 I/C, Sachs clutch & Unicorn custom map, S3 brakes, AP coilovers, THS mounts.
B8.5 Audi S4 with uprated pulley and unicorn Stage 2
Offline martziniuk
« Reply #7 on: May 08, 2012, 09:08:09 pm »
I would get a new inlet manifold seal as you don't want to be taking that off again if it's leaking.
Offline vRSAlex
  • -Receive: 253
« Reply #8 on: May 08, 2012, 09:16:19 pm »
Dv wire fits no problem.  I pull the wires back to the end of the coil pack harness which is the perfect length to reach the dv round the front.
Some of the early cars have bolts rather than threaded studs for the dv bracket.
Follow AKS tuning on Facebook
Offline DonalM
« Reply #9 on: May 08, 2012, 09:24:23 pm »
^^ That's the way my mechanic is doing it.
Says it's much neater.
I think the injectors Alex sells come with the fitting kit too.
http://www.mk5golfgti.co.uk/forum/index.php/topic,31784.0.html
TR DSG Gti- K04, TTRS Brakes, BBS, H&R, RNS, Xenons, Leather, Ed30 Front lip, US Smooth Grill, RVC, Miltek, WALK, Loads of Forge bits + lots more.
Offline vRSAlex
  • -Receive: 253
« Reply #10 on: May 08, 2012, 09:30:52 pm »
Much neater.  None of this cable tied wires running all over the place.
Sammy had some very low mileage used ones I had.  Fittings were good on them still.  Sold them then had to buy a new one for my car!  :fighting:
Offline martziniuk
« Reply #11 on: May 08, 2012, 09:35:15 pm »
Is it as easy to put back to standard afterwards? Wonder why APR supply the wiring harness.
I presume you wrap the bare wires in some kind of shrouding/heat shrink?
Offline Sammy
« Reply #12 on: May 08, 2012, 09:54:41 pm »
So it seems I have everything ready for the conversion then  :jumpmove:
Alex did you give me all parts needed for the s3 injectors also so plug and play?
Offline vRSAlex
  • -Receive: 253
« Reply #13 on: May 08, 2012, 10:25:41 pm »
The wiring will just go back to where it was before.  It's easier for the end user to use a harness, but its an extra cost that isn't needed.  The wiring is just pushed into the convoluted tubing that runs round the side of the head so no need to wrap until near the dv where its exposed.
Offline vRSAlex
  • -Receive: 253
« Reply #14 on: May 08, 2012, 10:26:33 pm »
All plug and play.   :drinking:
