Author Topic: cruise control - Issues!  (Read 4421 times)
Offline vRS_Pagey
  • -Receive: 59
« on: May 24, 2012, 05:54:17 pm »
I have retro fitted cc in both swmbo's GT and my vRS but just lately the one in the vRS is playing up, it will randomly turn off and can not be reactivated until the engine is turned off and on again?!  Then last week it wouldn't come on at all?  It was a used stalk but in excellent (new condition) and was initially fine, I understand you can pull the back of the stalk and disassemble to clean the unit.
If I have to get a new stalk is it a simple case of refitting, or will the car need recoding?
Cheers, Lee.
Offline DFish
Re: cruise control - Issues!
« Reply #1 on: May 24, 2012, 06:08:34 pm »
I had this with mine and it might just be dirty contacts. I bought some contact cleaner and cleaned the switch internals. I'll post a link tomorrow morning (unless someone beats me to it) as by the time I get home you'll be asleep. ;)
Fish
Offline Matto
  • -Receive: 116
« Reply #2 on: May 24, 2012, 10:42:39 pm »
From what I have read on here it the bad contacts syndrome only sewed to affect the older stalks. Think the newer ones have the speedo sign like this:
Also do you have any/scanned for fault codes? I know my mk4 pd150 wouldnt let the cruise work as there was a fault with the brake pedal switch. This is also tied in with the clutch switch too so if either are pressed it knocks the cruise off.
Offline DFish
« Reply #3 on: May 25, 2012, 09:50:02 am »
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #4 on: May 25, 2012, 09:58:49 am »
It's a prime example of why I don't think it's worth buying used stalks.
You can swap  it out, no coding required just clear the faults after.
Stu...
« Reply #5 on: May 25, 2012, 10:32:40 am »
^^^^^ this!
I've had problems with cruise on both my golfs. It's the flimsy 'contact' based design, they should have used a more sealed design.
Offline vRS_Pagey
  • -Receive: 59
« Reply #6 on: May 30, 2012, 12:48:00 pm »
Quick update - following the guide posted by Fish, I have cleaned all the CC contacts and reassembled, and the results .......... all working perfectly!  :happy2:
Offline mvb12
  • -Receive: 64
« Reply #7 on: May 30, 2012, 02:05:05 pm »
mine was playing up, i had the older style one, scanned it on VCDS it was coming up as "intermittent" error.
got a new style stalk and bobs your uncle.  :happy2:
Offline vRS_Pagey
  • -Receive: 59
« Reply #8 on: May 31, 2012, 12:34:10 pm »
Nice, did you buy a new one or was it a warranty job?  The contact cleaner was only 4 quid so happy with that.  :wink:
Offline Bogwoppit
« Reply #9 on: May 31, 2012, 12:40:49 pm »
I used SWMBO's nail varnish remover, worked a treat. Been OK for about 1.5 years since I cleaned it.
