Author Topic: Please tell me this is a coil pack problem...  (Read 2104 times)
Offline john a
    • The Veneers Cover Band
« on: July 24, 2012, 07:18:22 pm »
2.0 FSI Turbo - just changed the fuel pump cam follower and swapped out the PCV from a (suspected knackered) Rev C to a Rev N. I also replaced the breather hose from the PCV to the intake manifold after I snapped the clip when removing.
Car is now misfiring and VCDS shows the following. Am I right in thinking the coil pack on cylinder 1 is dead? There is a slight smell of fuel which I assume is because the fuel being injected into cylinder 1 is not being burned. Could it be another problem? Engine light came on initially but nothing since clearing the codes.
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1Z0 907 115 A    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0040
   Revision: 5BH16---    Serial number: SKZ7Z0F4012513
   Coding: 0203000318070160
   Shop #: WSC 00191 264 15243
   VCID: 336F3044522E491
Fault Found:
004949 - Cylinder 1 Ignition Circuit
               P1355 - 004 - Open Circuit - MIL ON
             Freeze Frame:
                    Fault Status: 11100100
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 107207 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 07:25:10
             Freeze Frame:
                    RPM: 460 /min
                    Load: 36.1 %
                    Speed: 0.0 km/h
                    Temperature: 17.0°C
                    Temperature: 18.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 11.684 V
Readiness: 0000 0000
Offline john a
Re: Please tell me this is a coil pack problem...
« Reply #1 on: July 24, 2012, 07:25:33 pm »
Oh - if I want to attempt to diagnose by swapping out the cyl 1 coil for either 2, 3 or 4 and then running the car, I'm not going to knacker anything am I?
Offline john a
« Reply #2 on: July 24, 2012, 07:45:32 pm »
Just had another quick look on the offchance that I had distubed the connectors - I don't want to speak too soon, but it's possible it may have been fixed by disconnecting and reconnecting the plug on the coil. I'm going to have me dinner, clear the fault code and go for a drive.
Offline bacillus
  • -Receive: 453
« Reply #3 on: July 24, 2012, 07:49:17 pm »
Have you logged for cylinder misfires iirc it's blocks 015 and 016?
Offline john a
« Reply #4 on: July 24, 2012, 07:50:36 pm »
I haven't as I didn't want to drive it - it's definitely 100% misfiring (sounds like one of those 3 cylinder corsas).
Offline bacillus
  • -Receive: 453
« Reply #5 on: July 25, 2012, 08:34:08 am »
If it's misfiring at idle then just log the car with it idling to see what cylinder you're getting the misfire on.
When did you last change your plugs as old plugs can cause a misfire...
