Author Topic: skoda fabia LED running lights?  (Read 18301 times)
Offline jedi-knight83
  • -Receive: 41
Re: skoda fabia LED running lights?
« Reply #15 on: August 16, 2012, 09:26:47 am »
not had time yet. currently focusing on installing my ICE (car is in bits and spread across various rooms in my house and sheds lol).
Once thats done I've had go ahead from VW for my rust so that will be another 2-3 weeks i expect.
Then when I have it back I can think about playing with these.
« Reply #16 on: August 16, 2012, 05:09:33 pm »
I have Hella LED DRL units on my Mk5 GTI:
http://www.mk5golfgti.co.uk/forum/index.php/topic,1917.0.html
Guess who fitted mine way back in 2009? - Shabba when he worked for my VW dealer.
Offline daboy3000
  • MKV GT TDi
« Reply #17 on: August 16, 2012, 05:13:36 pm »
So, to ask a stupid question, do you lose the fog light ability if you do these?  Where I live it can get very foggy very often so that extra bit of light really helps as main beam just makes it harder to see.
« Reply #18 on: August 16, 2012, 05:20:17 pm »
....Yes. Obviously front fogs only. It's a MOT fail not to have at least one rear foglight.
It can be very foggy (and heavy sea mists) in my neck of the woods too but I don't find it a problem and prefer to have the DRL's.
Offline apples12
« Reply #19 on: August 16, 2012, 09:29:05 pm »
With Ramadan nearly over and payday also around the corner this is near the top of the list  :smiley:
Going on my research there's a few ways to wire these in... They use the standard VAG 3 pin wiring system for DRLs ( a 100% pin, a 'dim' pin and common ground)
1. Wire them in as bog standard DRLs as you would your 'halfrauds' kit... (wouldn't really bother with this method)
2. Install a 3c0 30 byte CECM, wire in fogs if you haven't already straight to the CECM - activate fogs and cornering lights, activate fogs as drls and connect the skoda drls in place of your fogs - this way you'll get fog lights when you want them... Cornering lights when your low beams are activated, drls during the day!
3. Simply install them in place of fogs, wire them up as fogs as drls if you have a lower/less byte CECM
Number 2 is most desirable if you have the means, 2 is probably most feasible...1 is easiest!
MK6 GT TDI  - CW - LUX pack
GONE
MkV Golf 1.9TDI Sport in DBP, 160,000 miles and climbing!
Retrofits by me:GT front end,OEM bixenons with auto-levelling/washers, Valeo LED Rears, MFSW + Highline SWCM, Cruise Control, 30byte Highline CECM, Highline clocks, Rain/Light Sensor, Auto-dimming Rear view Mirror, RNS-510 LED (Ver H; SW: 4020), Fiscon Basic Bluetooth, MDI + Aux, Armrest, Reverse Camera LOW, TPMS..what next...
  • -Receive: 41
« Reply #20 on: August 16, 2012, 09:31:25 pm »
what is this cecm thing and how much is it and what else does it do?
with option 1... would you get the dim function if for instance you wire a switch feed into the dim pin.
Offline apples12
« Reply #21 on: August 16, 2012, 09:47:34 pm »
The CECM is the central electronics control module, controls all your lights etc. if your cars a 2007 or newer chances are you may already have a 30byte one installed especially if you have fogs (I got mine from a salvage skoda Octavia which was on a 57)
Tbh, I dont know how the dim function would work, I'm going to look into that properly at some point, I know you can get a controller which deals with it all but I would hope the CECM in the car would deal with it all what with it all being vag parts...
There's a guy on r32oc who installed the a6 drls on his r32 and had the dimming function, he used the controller, with this however you would lose the option of fogs I would have thought as I don't think you can run two 12 volt sources to the same pin on the CECM (you'd have one coming from your drl controller then one for your fog switch) so you'd get errors and it'd either not work or kill the LEDs.
Personally I want to retain the ability to have fogs (or at least something which resembles them) should I need them...plus I think the cornering lights look cool...lol
GONE
Offline Shabba168
« Reply #22 on: August 16, 2012, 10:03:04 pm »
Could it not be wired up through a change over relay for a ignition live to switch to dimmed when lights turned on
Offline apples12
« Reply #23 on: August 16, 2012, 11:22:24 pm »
Yup, that's the proper way of number 1 lol.
But...you would lose fogs...my goal is to retain as much oem function as possible...for those that have fogs already, wanting to go down this route would mean just buying these units, the wiring, cheap eBay fog housings and some coding...all reversible. Plus retain fogs!
GONE
« Reply #24 on: August 16, 2012, 11:28:19 pm »
....Am I missing something here? Fog lights and DRL's are quite different: The light from fog lights designed for purpose, is not the same as the LED light from DRL units. In the same location you either have fogs or you have LED DRL's, not both unless you fit extra light units.
There is a thread showing the LED DRL strip units which can be fitted in addition to keeping the OEM fogs.
« Reply #25 on: August 17, 2012, 07:41:01 am »
If you were to fit some aftermarket DRL lights and also keep your fogs, where would you take the power from???
Do people just connect to the sidelight wiring?
If this was done, would the DRL's just come on when the sidelights are switched on, or would they be on when ever the headlights are on?
I've got some DRL's that I think are gonna be real popular  :innocent:
« Reply #26 on: August 17, 2012, 09:07:08 am »
Im intrigued as to how you're going to drive around with yours on Carlo  :P :P  Cant wait to see peoples reactions  :party:
(When you finally get a build thread up!!)
Offline Eccie
  • -Receive: 25
« Reply #27 on: August 17, 2012, 10:19:44 am »
Apples is option 3 a straight 'plug n play' assuming you have the correct controller and can code it?
What about a bulb warning light, would this throw any up, or do you think the light unit somehow overcomes this?
« Reply #28 on: August 17, 2012, 10:58:03 am »
They aren't the DRL's I mean Mike.
(.....I show off my other lights later)  :wink:
« Reply #29 on: August 17, 2012, 12:32:28 pm »
