Author Topic: Do I need a manual for a radio  (Read 2307 times)
Offline wacky
  • -Given: 56
« on: July 31, 2012, 10:38:51 am »
Been looking for an RCD510 and speaking to someone selling one on ebay but it doesn't come with a manual.  I know - sounds dodgy to me as well !
If I was to buy it I am just concerned about fitting it and using it without a manual.
I have an ipod dock i the centre arm-rest.
Would it be easy enough to get up and running ?
I know most of us wouldn't use the manual that much anyway but just want to check before I decide to buy it or not.
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
Re: Do I need a manual for a radio
« Reply #1 on: July 31, 2012, 10:39:51 am »
Sure someone posted up a pdf version.... Have a look in the sat nav and radio section
Offline wacky
  • -Given: 56
« Reply #2 on: July 31, 2012, 10:56:19 am »
thanks, that was for the RNS510 but I guess that would cover most if not all of the RCD510 functions ??
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #3 on: July 31, 2012, 11:05:25 am »
Yeah it should, just ignore the sat nav part!  :signLOL:
« Reply #4 on: July 31, 2012, 02:22:03 pm »
Manual for RCD510 on pdf for you to download.
http://www.davecandoit.com/Cars/vw/RCD510Manual.pdf
You might also want the aerial adapter,from eBay (assuming your upgrading from a RCD300/RCD310), they are about £10.
http://www.ebay.co.uk/itm/VW-MFD3-RNS-RCD-510-310-315-210-radio-antenna-aerial-adapter-Seat-Skoda-Columbus-/251099055949?pt=UK_In_Car_Technology&hash=item3a76ab874d
Make sure it has a security code with it, it's just a 4 digit number which you enter into the head unit once it's installed. Without that I believe only VW will be able to help, could be wrong though.
Hope that helps  :happy2:
« Last Edit: July 31, 2012, 02:25:07 pm by MC71 »
Offline wacky
  • -Given: 56
« Reply #5 on: July 31, 2012, 02:30:15 pm »
thanks so much that a big help !
can anyone recommend a nice DAB aerial ?
« Reply #6 on: July 31, 2012, 02:51:10 pm »
Have a look on this website, loads of different options re aerials for DAB. Would recommend an internal glass mounted one (goes vertically on the front windscreen on the far left side, passenger side)
Below is a link to the various aerial options
http://www.dabonwheels.co.uk/DAB_car_aerials.html
« Last Edit: July 31, 2012, 02:53:13 pm by MC71 »
Offline ianv5
« Reply #7 on: July 31, 2012, 03:03:42 pm »
I have the stick on one works fine.
You don't need the aerial adapter for the am/fm. Have posted this before but the plastic pieces on the ends of your original aerial leads come apart if you slide out the small purple pieces and then the remains unclip. You are left with just the metal connectors which push straight into the back of your new radio :happy2:
It was me who posted the PDF for the RCD510 as I did not have one originally and found the link :happy2:
« Reply #8 on: July 31, 2012, 04:06:18 pm »
^^^^ was your post that I copied it from Ian.  :notworthy:
After buying the head unit from you I went looking for a manual on the forum and low and behold I came across that PDF, by you, small world!!
Offline Frenzy
  • -Receive: 29
« Reply #9 on: July 31, 2012, 04:06:34 pm »
If you are a man - no (i'm surprised you're having to ask)
If you are a woman - it's up to you
 :signLOL:
« Reply #10 on: July 31, 2012, 04:20:07 pm »
^^^^ I love a good manual, have read my Golf manual from cover to cover (can't remember any of it) and found out loads of useless useful things.  :smiley:
It's instruction on flat pack assembly that get ignored in my house!  :signLOL:
