Author Topic: Can you mix brands of oil as long as same quality/VW spec?  (Read 5267 times)
Offline berg
  • -Given: 49
  • -Receive: 38
« on: August 28, 2012, 11:28:15 am »
As above, I have Castrol 5W/30 in at the moment but wanted to try the Millers Nanodrive. Can I top up with 5W/30 Millers or is it not advisable to mix different brands even if meet VW504 spec etc?
Thanks.
Offline john87
  • -Receive: 53
Re: Can you mix brands of oil as long as same quality/VW spec?
« Reply #1 on: August 28, 2012, 12:09:19 pm »
mixing brands when topping up is perfectly fine, as long as they are both of the same type i.e. fully synthetic  :happy2:
Offline sideshowfred
« Reply #2 on: August 29, 2012, 09:05:59 am »
Isn't nanodrive that new one that's supposed to up your bhp?? If so surely it wouldn't give any of the benefits just mixing it in with normal oil.
« Reply #3 on: August 29, 2012, 09:13:27 am »
....Really?  :surprised: How does an oil up bhp? :surprised:
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #4 on: August 29, 2012, 09:18:51 am »
Decreasing friction between engine components.
Porsche demonstrated similar results to what Millers are claiming on their Cayenne models by using low friction oils in a study a few years ago.
vRSAlex swears by Millers CFS, says it even reduced his cam follower wear.
PLANS: Stage 2+
« Reply #5 on: August 29, 2012, 09:19:34 am »
I don't know but reading this seems to suggest the same thing http://www.millersoils.co.uk/nanodrive.asp
« Reply #6 on: August 29, 2012, 09:30:57 am »
....Thanks, sub  :happy2: I'm glad I challenged it.
Hmm, sounds good stuff - Is Millers Nanodrive oil much more expensive?
What attracts my interest is its claimed maintenance benefits rather than the extra bhp.
Offline Tamiyoman
  • -Receive: 39
« Reply #7 on: August 29, 2012, 10:10:52 am »
In the millers oils app guide they don't seem to offer 5w/30, only 5w/40
« Reply #8 on: August 29, 2012, 02:11:58 pm »
When I spoke to Alex, he said a tuned car tends to work harder than OEM spec so 5W-30 isn't enough but 5W-40 is best.
Offline Tamiyoman
  • -Receive: 39
« Reply #9 on: August 29, 2012, 02:21:03 pm »
Cheers for that, will get some of this and give it a try for next oil service in another 2k (change it every 6k which is once per year!).
« Last Edit: August 30, 2012, 09:31:25 am by Tamiyoman »
« Reply #10 on: August 29, 2012, 02:22:18 pm »
Methinks that, subject to JKM's advice, it'll be 5W-40 Millers Nanodrive for me next oil change. I change oil every 10k miles. (Stage 2 K03)
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #11 on: August 29, 2012, 10:17:07 pm »
yup, i was going to try and switch over to it, opie oils has it at just over £60.00 for 4 litres so yes it is more expensive than the others but if it is genuinely superior would pay it
« Reply #12 on: August 29, 2012, 10:44:32 pm »
How would I know which oil (5W-30 or 5W-40) is best for the engine in my Stage 1 Eddy?
« Reply #13 on: August 29, 2012, 10:47:51 pm »
I'm the same and use 5W-40 at the advice of alex.
« Reply #14 on: August 29, 2012, 10:54:46 pm »
^^^^ thanks Stealth, most helpful.  :happy2:
