Author Topic: Steaming up - best climate control settings  (Read 11145 times)
Offline Max99
  • White GTi owner
« on: November 16, 2012, 10:41:55 am »
May be bit naive of me, but what are the best settings to remove moisture from the air/inside of my car? Recently everytime I get into the car the front windscreen on the inside has condensation on it.
Any tips?
Also general what's best to have the climate control on in terms of 'econ' on or off, 'auto' on or off, recirculation, facing front, up down etc :)
Offline Squeeguk
Re: Steaming up - best climate control settings
« Reply #1 on: November 16, 2012, 10:49:16 am »
Leave it on auto with the aircon button switched on, also make sure recirculate is off. This is the best way to keep the interior from misting up and get rid of the mist. If the windscreen is really misted up, press the windscreen defrost button and then switch back to auto once it's clear. My aircon button is always on, regardless of the temps. That is the whole point of climate control. Set the temp and let it do it's thing.
« Reply #2 on: November 16, 2012, 11:18:01 am »
Leave the A/C on all time and adjust the temp to your liking as you go. I always leave it on and just 1 bar of power, never get steamed up.
Offline dan930
  • -Receive: 56
« Reply #3 on: November 16, 2012, 11:37:47 am »
You can buy something from halfords to prevent misting up if you don't want to put the ac on... Forget what's it called
MK6 golfR dsg
AKS TUNED
NORTECH PERFORMANCE HTA3071
R TECH custom map
Offline andrewparker
  • -Given: 32
  • -Receive: 78
« Reply #4 on: November 16, 2012, 12:05:47 pm »
An application of Rain-X on the inside helps too...
  • -Given: 32
  • -Receive: 78
« Reply #5 on: November 16, 2012, 12:09:00 pm »
Offline richtung
  • -Receive: 56
« Reply #6 on: November 16, 2012, 12:14:36 pm »
And it seems like they have a dedicated product now -
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_201119_langId_-1_categoryId_255225
Pretty poor reviews though.
I have used this - its a waste of time to be honest. I find that if you give the inside of the glass a good clean and as mentioned, leave the aircon on, it will minimise the steaming up.
Rich
Offline rsreid2000
« Reply #7 on: November 16, 2012, 12:20:00 pm »
Do you find it has an effect on your MPG leaving it on all the time.
Offline Lone_Par
« Reply #8 on: November 16, 2012, 02:01:55 pm »
Same here, though I always leave it on ECON. Only rarely does the windows steam up and when they do, I just switch it onto windscreen only to clear, then back to ECON. I should add that the windows only tend to steam up if my son has been in the front and turned the vents off!!!  :fighting:
Offline Squeeguk
« Reply #9 on: November 16, 2012, 11:27:18 pm »
Keep in mind, in Econ mode, the aircon compressor does not run. This is not a good idea to not let it run for long periods. The oil does not circulate through the system keeping the O-rings lubricated, this can lead to leaks which can be costly to repair. You should always run you aircon regularly for at least 10 minutes at a time.
Offline Lone_Par
« Reply #10 on: November 16, 2012, 11:43:01 pm »
Thanks mate. Will bear that in mind.
Offline bushypad
  • -Given: 18
« Reply #11 on: November 17, 2012, 03:22:33 pm »
I always leave it on ECON also as i was advised to otherwise the aircon would be running?! but you are saying it is ok to leave it running and just put the temp up?
Offline NotNormal
« Reply #12 on: November 17, 2012, 03:33:22 pm »
Change the micro filter / pollen filter, clean the screen with windowlene (or similar)
Jobs a good'un
Tom
Don't judge me by your ability !
__________________________________
Current daily crapper - Audi A6 Avant 3.0tdi SLine Quattro
Previous favourite rides :
BMW E92 335d M/Sport (351/520)
BMW  E92 335d SE (339/500)
Golf MK5 GT170 Diesel Sport (220/330)
Audi S4 (B6) - Noggy blue (366bhp)
Evo VI (6 ;) ) RSII - Scotia White (420bhp)
Astravan Sportive 1.9 CDTi - 190bhp
Astra GTE (MK2) Turbo (
Offline Squeeguk
« Reply #13 on: November 17, 2012, 04:52:13 pm »
Yeah, it's actually better for the aircon system to be run most if not all the time. The whole point with climate control is that you set the temp and the system does the rest if set to auto. Using sensors, it decides where best to put the air to maintain the desired temperature.
No idea on fuel consumption as I never switch mine off. There were some tests conducted many years ago in South Africa where it get's really hot, as I am sure you are all aware, so the air conditioning really has to work hard to earn it's keep. The test was to check the effect of air conditioning on fuel consumption and it worked out that it used less fuel to use the aircon on the motorway than opening the windows, but obviously there was a penalty compared to running without aircon and with the windows closed.
Offline suave
  • -Given: 31
« Reply #14 on: November 17, 2012, 07:44:23 pm »
This worked for me - pollen filter is only around a tender and easy to change with a Torx T20 tool
