Author Topic: chrome window buttons  (Read 4218 times)
scottm72
« on: November 23, 2012, 01:08:57 am »
anyone know where to get the chrome tips for the window buttons
Offline marko
Re: chrome window buttons
« Reply #1 on: November 23, 2012, 02:22:32 am »
2007 TR gt170...heated leather,underseat drawers,auto-levelling bi-xenons,puddle leds,chrome switches,footwell lights f+r,cruise control and ed30 rear lamps,LED interior....carbon highline clocks,ed30 front spoiler,RNS 510 P+MDI,mk6 gti gearknob,TPMS done,complete r32 trim kit+ MFSW,r32 f+r brakes,RLS fitted.headlamp washers,folding mirrors and boot pop,mk6 RVC,19"Helios,AP coilies,valeo LEDs  ...dpf delete and remap to finish off
« Reply #2 on: November 23, 2012, 07:28:45 am »
And don't forget your fuel flap switch. Door card off though I'm afraid, right PITA.   :laugh:
http://www.bold-sport.com/store/index.php?route=product/product&product_id=107
AA
« Reply #3 on: November 23, 2012, 08:12:48 am »
 Fuel switch is the easy one to change  :happy2:
Offline chrisr763
  • -Receive: 62
« Reply #4 on: November 23, 2012, 08:21:16 am »
Its a shame its such an expensive mod for somthing relativly simple  :stupid:
« Reply #5 on: November 23, 2012, 08:44:27 am »
Not for me!  :ashamed:
Found it a pain to get the door cards off so had Eddie-NL switch them over while having my LED door warning lights fitted. The others are all a 10 minute job with some trim tools.
They are VERY cheap fella, the ones in the link. The ones i purchased were over £100 for a 3r set inc. Headlight switch and Fuel Flap switch.
Offline chrisr763
  • -Receive: 62
« Reply #6 on: November 23, 2012, 02:01:15 pm »
Didnt realise it was in Dollars  :grin: But the 3 Door ones are $129.99
« Last Edit: November 23, 2012, 02:04:26 pm by chrisr763 »
homesqueeze
« Reply #7 on: November 23, 2012, 04:30:13 pm »
It's meant to be possible to change the fuel flap switch without taking the door card off. I'll find out when I change all my switches after I get them for Crimbo!
« Reply #8 on: November 23, 2012, 04:39:03 pm »
^^^^ had this discussion with a few peeps (including Eddie-NL when he changed mine) and is "possible" if you remove all the screws (including the ones holding the handle to the door) and pop the bottom lugs out and a few up the sides and you can squeeze your hand underneath the lever the switch out. Some peeps have tried to lift the plastic surround that is around the switch put it won't lift enough as its attached to the door card from behind and will break off if forced. Is all a PITA though, easier to take the door card off.
homesqueeze
« Reply #9 on: November 23, 2012, 04:43:19 pm »
Fair enough, I'll bear that in mind when I try and change mine.
AA
« Reply #11 on: November 23, 2012, 04:59:05 pm »
Yeah, it was a fail (for me) as I couldn't get the lugs undone. Some may have better luck bending the door card.  :ashamed:
scottm72
« Reply #12 on: November 23, 2012, 09:47:56 pm »
holy sh*t man, because there is a little notch at the end of the normal switches I thought something would clip on and house there.
so am I right in thinking I would have to take ALL the door panels off if I bought the set ?
and what about the headlight switch, panel off again ?
also would any coding be required after install
Offline Nodz
  • -Given: 73
  • -Receive: 103
« Reply #13 on: November 23, 2012, 09:56:32 pm »
No coding, and only trim off around the switches for window switches, headlight switch pops out easily and fuel switch requires the door card to come off
scottm72
« Reply #14 on: November 23, 2012, 10:48:55 pm »
window switch on every door, is it just that bollard it sits on that pulls of then on each door
isn't the fuel switch in the middle console, sorry to cold to go outside and check
also I guess the buttons illuminate like the standard ones ?
are these easy for noob to fit
