Author Topic: RNS 510 SD card issues?  (Read 4950 times)
Offline ell.s
« on: November 23, 2012, 08:35:12 pm »
Well just got an sd card through the post and loaded some albums on it, when I've come to put in in my RNS 510 and it sees the card but not any of the music, isn't there any particular format the files need to be in or way of getting the unit to see the music? Cheers!  :happy2:
Offline SI-R32
  • -Receive: 126
Re: RNS 510 SD card issues?
« Reply #1 on: November 23, 2012, 08:41:35 pm »
what format have you got them in then?
Offline ell.s
« Reply #2 on: November 23, 2012, 08:48:42 pm »
I will have to check but I believe they are mp3's but will have to check.
Offline SI-R32
  • -Receive: 126
« Reply #3 on: November 23, 2012, 08:49:52 pm »
should be fine then even if in folders
Offline ell.s
« Reply #4 on: November 23, 2012, 08:55:46 pm »
They are in folders :/ ill have a look and post some pics of my files.
Offline SI-R32
  • -Receive: 126
« Reply #5 on: November 23, 2012, 08:59:06 pm »
what size is your card and how old/what firmware is the 510 running if you know?
Offline ell.s
« Reply #6 on: November 23, 2012, 09:03:40 pm »
It's a 32gb card, how do I find out can I access it from the menu? Sorry only had the car less than a week  :ashamed:
Offline SI-R32
  • -Receive: 126
« Reply #7 on: November 23, 2012, 09:08:14 pm »
one obvious thing to check the button next to eject is it an I or a star.
if it allows you to see hold the setup button down for about 20 secs if it stops on AM FM then you can't find out, if it goes past AM FM to next screen then the firmware will be on there 4 digit number
32gb might be 2 big for the unit to read you see, can you try a 2 or a 4 first?
Offline ell.s
« Reply #8 on: November 23, 2012, 09:22:35 pm »
I've only got 2 32 gb cards unfortunately :( just been out by the car and took this there is an "I in the top corner and this is the version number.
Offline SI-R32
  • -Receive: 126
« Reply #9 on: November 23, 2012, 09:25:54 pm »
thats really early firmware 1100 and you have a version B unit, i'm positive you can only use a 4gb card in it for now, you can update the firmware on the 510 at some point to allow bigger cards and for it to do other stuff but this will defo be your problem mate.
Offline ell.s
« Reply #10 on: November 23, 2012, 09:31:03 pm »
Ahh that sucks will my unit take the latest software? If so is there anyone on here that could sort me out or is it a case of download and burn? Cheers for the help
Offline SI-R32
  • -Receive: 126
« Reply #11 on: November 23, 2012, 09:35:18 pm »
it cant be latest but check this out
http://www.my-gti.com/1769/volkswagen-rns-510-firmware-upgrade-to-version-2680-2682-2684-2686-2688
also you might want to contact eddie-nl on here and ask his advise on exactly what one would be best mate
Offline ell.s
« Reply #12 on: November 23, 2012, 09:44:17 pm »
:( damn as long as I can use some of the later features, thanks for all your help dude! I'll contact him now.  :happy2:
Offline hardhat
« Reply #13 on: November 23, 2012, 11:06:54 pm »
Hi, hope you don`t mind if I jump in here- I too just had my car this week, so does it mean if you can`t get past the AM FM screen I can`t find out about my 510 unit? I`d like to add bluetooth sometime.
Offline SI-R32
  • -Receive: 126
« Reply #14 on: November 24, 2012, 03:12:07 pm »
you'll probably be able to add blue tooth no problem, if your can't get past am fm screen holding down the set up button, someone with vcds needs to change a zero to a 1 somewhere for it to display your firmware etc.
fyi is there a star or I button next to eject as early rns has I later from C ish onward has star, i had Bluetooth connected to my B unit no problems
