Author Topic: Nightmare on F/W updating - HELP Required  (Read 4883 times)
Offline Kiwi
« on: March 09, 2013, 02:24:31 pm »
So I have the following
RNS 510 C - currently running 2760 F/W and Maps Version 7551
I have downloaded the firmware files from RNSfirmware.com  and from the my-GTI, I have versions 3810a and have Euro 4120 firmware.
I have bought Verbatim Discs DVD-R, TDK CDRw and Traxdata CD-R, but none of then get pass the full install stage, the RNS510 see's the image, see pictures below.
So apart from hanging myself, or driving the car into a brick wall, what on earth can I do...................
Someone help me out........... Does anyone have a disc that they know will 100% work??
Looking forward to your help
Offline skard
  • -Receive: 245
Re: Nightmare on F/W updating - HELP Required
« Reply #1 on: March 09, 2013, 02:37:36 pm »
Did you burn at a low speed?
Offline Kiwi
« Reply #2 on: March 09, 2013, 03:12:31 pm »
Yes mate, lowest it would go was x4 speed
Offline skard
  • -Receive: 245
« Reply #3 on: March 09, 2013, 03:17:05 pm »
There was no 1x or 2x option?
I'll report back later what brand I used, I had one failed attempt but then worked fine next attempt
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #4 on: March 09, 2013, 03:25:19 pm »
Can firmware discs be used more than once?
Offline skard
  • -Receive: 245
« Reply #5 on: March 09, 2013, 03:31:22 pm »
Yep unless they get scratched/damaged
Offline Kiwi
« Reply #6 on: March 09, 2013, 03:36:28 pm »
I requested x1 speed, but reading the info as displayed it was writing at x4 speed
Offline bacillus
  • -Receive: 453
« Reply #7 on: March 09, 2013, 07:26:39 pm »
This may sound stupid but try burning the dvd on a different burner as some burner chipsets are more likely to burn a dvd that fully readable on your rns510 trhan others.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #8 on: March 09, 2013, 07:32:24 pm »
I would only use verbatim and nothing else.
Could be a corrupt download. Would try downloading again and as said above try a different burner.
Offline Kiwi
« Reply #9 on: March 09, 2013, 08:52:04 pm »
Thanks guys for all your suggestions help,
I'll try downloading it again.
Will download IMG Burn again
I'll try all of this on a different PC
Fingers crossed for tomorrow and I try this all again................................
Offline Kiwi
« Reply #10 on: March 09, 2013, 10:31:20 pm »
Well I've tried everything,  to no avail......
So 2xLaptops and 1X Home PC later and I'm still stuck, oohh did I mention 10 discs too and 2 lots of Firmware 3810a and 4120
and all I get is error
Then this
But it says this
Dis-heartened doesn't come close...........
Any ideas on what to do, or links to something
Offline skard
  • -Receive: 245
« Reply #11 on: March 09, 2013, 10:35:18 pm »
If I recall you have to load 3810 to get the new partition layout, then 4120 thereafter.
I have 4020 on mine.
Offline bacillus
  • -Receive: 453
« Reply #12 on: March 09, 2013, 10:46:20 pm »
What format is your clock time? If 24 hr try changing it to 12 hr and then try the update again.
Offline Kiwi
« Reply #13 on: March 09, 2013, 10:52:09 pm »
I've also had and been trying 3810a firmware update, and still same errors
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Re: Nightmare on F/W updating - HELP Required
« Reply #14 on: March 10, 2013, 08:42:09 am »
What fw are you on at the moment?
If you're on something really low then it may be worth trying a lower fw first like a 2760. And then upgrade to 3810
Sent from my GT-I9300 using Tapatalk 2
