Author Topic: Oil Use  (Read 3798 times)
Offline RifGTi
Re: Oil Use
« Reply #15 on: May 10, 2013, 01:37:10 pm »
Ive got a BWA engine since getting it ive done around 5k miles ( since December and it had a full service before I drove it away) and used just over a litre
it is known to drink 1l for every 1000km
Offline f1fan
Re: Oil Use
« Reply #16 on: May 11, 2013, 08:12:29 am »
My 08 GTi was serviced & oil changed in August, since then I've done 10,000 miles, the warning light has come on twice over that time and I've put 1.5 litres in to keep it happy.
I can a 1l castrol edge in the little cubby hole in the right side of the boot now, £20 a litre it's not a cheap oil!
Black 2008 GTi, InPro smoked door mirror indicators, genuine Autohaus Wolfsburg plate holders, uk legal pressed metal plates, LED number plate lights, MTEC super white headlights & side lights, LED internal lights, Polo stubby aerial, Kenwood DDX4023BT head unit & Enfig surround.
homesqueeze
Re: Oil Use
« Reply #17 on: May 11, 2013, 08:33:19 am »
Morning Guys,
Just a bit of opinion needed really?
Back at the beginning of march i had a full service done on my car including a full oil change.
When i got into my car this morning the Oil check notification came up, 2 months seems to be a short time period to be going through that much oil, or is that just me?
Many Thanks
Did you check your oil level straight after the service. It is not uncommon for dealers to not fill it up enough after an oil change, leaving it low straight away. It has happened to me. If this is the case then you haven't used as much as you think you have.
homesqueeze
Re: Oil Use
« Reply #18 on: May 11, 2013, 08:35:33 am »
You're getting your Castrol from the wrong place! Try Euro car parts with a discount code, you'll get it much cheaper than that!
Offline f1fan
Re: Oil Use
« Reply #19 on: May 11, 2013, 10:14:40 am »
Both bottles I've bought from Halfords as its next door to my office and I needed it quick, £19.99, paying extra for the convenience!
I see Europarts is £17, where did you get your discount codes from?
Offline numec
Re: Oil Use
« Reply #20 on: May 11, 2013, 11:04:57 am »
Asda for 12 quid.. :happy2:
Offline beetie
  • -Given: 34
Re: Oil Use
« Reply #21 on: May 11, 2013, 12:30:06 pm »
If the pcv is dodgy then it will use more oil than it should.
Offline GTI5
Re: Oil Use
« Reply #22 on: May 11, 2013, 02:11:40 pm »
Morning Guys,
Many Thanks
Hi
Can you tell us how many miles you have done in 2 months? Consumption is relative to mileage not time, so if you did 5000 miles in that time period then this may be fine.
It seems some peoples drink others don't, I had a 55 plate BWA that used close to 1l in around 1300 miles on Castrol Edge 5W40 and 1l in just under 2500 miles on Redline 5W40 (Better profile than Castrol BTW...but more pricey).
The oil consumption was the main reason I sold the car to trade, for me it was a real PITA and let the car down. I did nearly 30k in it and wished I had ditched it sooner.
VW and all manufacturers will covers themselves with the 1l in 600 miles BS but that was unacceptable for me. Sure a combustion engine will consume some oil but the levels quoted are ridiculous imo. It bothers some people and not others, it bothered me because it's a sign of inefficiency.
A main dealer wont look at the car unless it falls below those parameters.
I never found out where the oil was going, there was no visible signs in the exhaust gas either. Unless you're willing to have the engine and components stripped (lot's of £££) then you either keep topping it up or find another car.
I now have a MK6 and so far so good.
« Last Edit: May 11, 2013, 02:14:03 pm by GTI5 »
MK6 GTI Revo
MK5 GTI DSG - Gone
Offline f1fan
Re: Oil Use
« Reply #23 on: May 11, 2013, 02:28:02 pm »
Can you post a link? I checked the Asda site & I can't find the Castrol Edge 5w30 1 litre anywhere.
Offline winrya
Re: Oil Use
« Reply #24 on: May 11, 2013, 02:32:35 pm »
My aax engine used a litre in first 10k and has never used a drop since and is now on 56k
Offline wagonboy
  • Nov.2007 ED30 dsg reflex silver
Re: Oil Use
« Reply #25 on: May 11, 2013, 04:06:11 pm »
I have never needed to 'top-up' the oil between services on my 57 plate ED30 (which I am obviously quite happy about   :smiley:)
homesqueeze
Re: Oil Use
« Reply #26 on: May 11, 2013, 04:30:28 pm »
They usually show you the current code on their homepage. It's changing quite often. Its usually worth up to 20 - 25% off.
