Author Topic: DV help P/N?  (Read 2273 times)
Offline Andygolf
DV help P/N?
« on: May 27, 2013, 07:17:07 pm »
Evening all.
I think my DV needs changed as under load/acceleration you can hear a boost leak.
I have been hunting about for what the correct p/n for my dv should be I phoned up my local dealer and wasn't very helpful so I would like to go in tomorrow morning armed with the correct info.
My car is an 05 with 54000 miles on the clock and I don't think it would of been changed once. Also is this quite an easy job to-do?
Any info and p/n would be great.
Re: DV help P/N?
« Reply #1 on: May 27, 2013, 07:18:14 pm »
Revision G is the one your after. Part number is 06H 145 710 G
Offline Andygolf
Re: DV help P/N?
« Reply #2 on: May 27, 2013, 07:21:37 pm »
Thanks for the quick reply MC71. I will be armed ready for the morning. Any advice on fitting?
Re: DV help P/N?
« Reply #3 on: May 27, 2013, 07:24:56 pm »
No worriers!  :drinking:
Yours can be a pain (being a K03) to change. Here's a guide (below). Have a good read through....
~~ Clicky here ~~
« Last Edit: May 27, 2013, 07:32:32 pm by MC71 »
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
Re: DV help P/N?
« Reply #4 on: May 27, 2013, 07:27:01 pm »
http://www.mk5golfgti.co.uk/forum/index.php/topic,44709.0.html
This guide is for a standard gti. You can also change it by removing the osf wheel and arch liner.
If you have an ed30 or Pirelli the DV is in a different location; you access it from the engine bay, a very simple job.
'07 Red manual
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
Re: DV help P/N?
« Reply #5 on: May 27, 2013, 07:28:50 pm »
^^^ Goddam quick on the draw Martin! The forum's top gunslinger :laugh:
'07 Red manual
Re: DV help P/N?
« Reply #6 on: May 27, 2013, 07:35:42 pm »
.....and this PDF is good guide, uses Forge's guide on fitting a Bypass Valve Kit so gives all info on the K03 DV....
~~ Clicky here ~~
Offline rob-gti
Re: DV help P/N?
« Reply #7 on: May 27, 2013, 10:31:21 pm »
I changed mine the weekend, makes some difference! My gti is fast again  :laugh:
Offline Andygolf
Re: DV help P/N?
« Reply #8 on: May 28, 2013, 09:49:02 pm »
I was in a vw today and they said the part number should be 06F 145 710 G does this sound correct?? Was £40 all in.
Re: DV help P/N?
« Reply #9 on: May 28, 2013, 09:57:52 pm »
^^^^ yes, that's right, sorry I meant F not H, getting mixed up with the old Rev' D.  :ashamed:
P/N = 06F 145 710 G
