Author Topic: Home made terminal tool!  (Read 4157 times)
Offline galaxie500
  • -Given: 38
  • 56 plate 5 door in Black Pearl Metallic
« on: June 06, 2013, 11:25:11 pm »
I managed to break the connector to my fuel pressure switch whilst I changed the fuel pump cam follower last week and not wanting to buy the bespoke tool to remove the wires from the connector I've come up with a cheap solution which works perfectly and is available on every High street in the country.
A nit comb!!
I've removed a few tines to the correct distance apart which allows the two remaining tines to slip down the sides of the connector releasing the crimped terminal end. I've removed the middle two from a block of four and will then remove a few more to allow free access to the centre terminal. The only thing to watch is if the tines pull out of the handle.
I have used a paper clip previously but this seems more reliable.
galaxie500
Offline omeydz
  • -Receive: 50
Re: Home made terminal tool!
« Reply #1 on: June 06, 2013, 11:37:11 pm »
Great ingenuity there mate!!  :happy2:
Recently back on the forum! Good to be back
Current Rides
Mazda RX8 231bhp ( very different little rocket lol!)
SOLD
2007 MK5 Golf 1.4 FSI
2007 Golf MK5 GTI DSG
2008 Audi A5 3.0TDI
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #2 on: June 06, 2013, 11:38:59 pm »
Very enterprising!  :happy2:
'07 Red manual
Offline Simon_2.0t
« Reply #3 on: June 07, 2013, 12:48:35 am »
Wow great idea mate. I've done the same with my plug, where did you get the replacement from? And the wires?
Part numbers be great cheers Si
Offline galaxie500
  • -Given: 38
« Reply #4 on: June 07, 2013, 08:37:48 am »
Hi Simon
Plug & wires from VW Main dealer.
Plug - 3BO 973 703 G
Pic of old plug
Repair wires - 000 979 131 EA
Should be able to release the original loom wiring from the broken connector but if that proves difficult, the repair wires will slip straight into the new connector once the purple lock tab has been slid out.
The only problem I foresee is when my wife finds out what I've done to the Nit comb. Better go to Boots later!
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #5 on: June 07, 2013, 09:01:44 am »
Why? Does she have nits?  :surprised:
'07 Red manual
Offline Simon_2.0t
« Reply #6 on: June 07, 2013, 09:27:24 am »
Cheers mate, just to confirm before I order. This is to plug in the top of the fuel pump?
This one:
Offline galaxie500
  • -Given: 38
« Reply #7 on: June 07, 2013, 10:04:34 am »
Whoops!
I put the wrong pic up of the 'tool' in use!
Here it is with the nit comb tines correctly positioned for terminal removal!
Offline galaxie500
  • -Given: 38
« Reply #8 on: June 07, 2013, 10:17:43 am »
Hi Simon
That's the one. Mine was spun 180 degrees round so the clip part easier to see. Even more stupid that I broke it!
Hi Tortaruga; My daughter (10) has had Nits - the girls get them more than the boys from sharing hair - brushes, clothes etc. fortunately there's no Nit issue at present. The school sends out notes when there's a problem. No one is blamed but we all know they originate at the soap-dodging Pikey family on the estate.  :signLOL:
Offline Simon_2.0t
« Reply #9 on: June 07, 2013, 10:29:24 am »
Cheers just ordered all up, collection tomorrow.
Is the nit comb to remove the terminals from the old clip? Or help fitting new ones? Sorry bit dumb  :sad1:
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
« Reply #10 on: June 07, 2013, 10:46:29 am »
Supposedly nits prefer clean hair, whether that's said to make the scummy kids feel better I don't know, lol.
Offline galaxie500
  • -Given: 38
« Reply #11 on: June 07, 2013, 10:56:32 am »
The terminal release tool (Nit comb model) is only required to release the wires from the plug. The terminals just click into place once the purple Lock tab is removed. Repair wires are just in case a terminal breaks and can be used for a number of different plugs.
Offline Simon_2.0t
« Reply #12 on: June 07, 2013, 11:37:40 am »
I get it, thanks.
So if all goes well, can just replace the plug.
Thanks Si
Offline galaxie500
  • -Given: 38
« Reply #13 on: June 07, 2013, 03:44:19 pm »
Precisely.
A little tension on the wire as the tool is inserted should ease it's passage out of the back of the plug.
Good luck.
Offline Simon_2.0t
« Reply #14 on: June 07, 2013, 03:52:27 pm »
Cheers mate, zip tied on at the moment  :ashamed:
