September 13, 2026, 01:22:16 am
All Things Mk5
Mk5 General Area
Replacing rear spring(s)
Topic: Replacing rear spring(s) (Read 5253 times)
Wolfsburggti
Just Arrived
-Given: 1
-Receive: 1
June 19, 2013, 07:54:12 pm »
My off side rear spring has snapped. Any guides on how to change? Have had a quick look but can't find much...
Also is the done thing to change both sides, rather than one?
Thanks...
ukshaun
Always Involved
-Given: 0
-Receive: 6
If in doubt.. flat out
Re: Replacing rear spring(s)
Reply #1 on:
June 19, 2013, 07:59:44 pm »
Yes you should change both sides together really.
You don't really need a guide for the rear they are easy. All you need to do is jack the car up remove the wheels and use a pair of spring clamps to compress the current spring then undo the shock absorber and have someone push down on the hub whilst you lift the spring out. Then compress your new spring and do the same in reverse. Make sure you seat them correctly on the rubber mounts or you will get a horrible squeaking.
My progress thread
www.mk5golfgti.co.uk/forum/index.php/topic,66117.0.html
Mods done: revo map, new south boost gauge, rcd510 dab, gti grill, gti colour coded valance, tinted lights, leds, gti spoiler
Wolfsburggti
Just Arrived
-Given: 1
-Receive: 1
Reply #2 on:
June 19, 2013, 08:07:23 pm »
Excellent, sounds very similar to a BMW E46, the springs for which I've changed before. Is it easy to get the compressors on to the spring whilst it's still on the car? I remember strugglng with that with the beemer.
skard
Just look at my post count
-Given: 5
-Receive: 245
My Ride:
Reply #3 on:
June 19, 2013, 08:08:45 pm »
I've never even used spring clamps, just undo the pinch bolt and it all drops out, to refit slowly and carefully jack up the arm, then stick the bolt in and tighten.
Andy
Admin
-Given: 39
-Receive: 447
Reply #4 on:
June 19, 2013, 08:18:47 pm »
as Skard says is the way I do them as well
gttdi build thread
r32 build thread
Chris92
Won't Shut up.
-Given: 33
-Receive: 35
If you're smart in this world they call you crazy
My Ride:
Reply #5 on:
June 19, 2013, 09:58:16 pm »
X2 for skards way, maybes place a jack under the arm before removing the shocker bolt then let jack down and lift spring out its just a more controlled way of doing it. Easy job is the rear springs you'll have no problems.
All Things Mk5
Mk5 General Area
