Author Topic: Clutch is slipping  (Read 1439 times)
Offline DomBacon
Clutch is slipping
« on: September 17, 2013, 05:52:56 pm »
Finally got round to getting a revo stage 1 map
Had no problems with my clutch slipping before hand but as soon as it got mapped and I took it out for a spin it started straight away :(
Was looking at the LOBA single mass flywheel and Sachs clutch kit
Is anyone running this kit? Is it worth it?
I'm only planning to go stage 2 and that's it
Anyone recommend a better clutch kit?
Thanks Dom.
Re: Clutch is slipping
« Reply #1 on: September 17, 2013, 06:00:19 pm »
Foe most peeps a SMF is the more track/fast option and the DMF is more of a normal/fast road answer so depends what your doing with you car.
As well as the Organic Sachs look at Helix, that's the one I'll be getting when/if I need one.
Offline xjay1337
  • -Receive: 377
« Reply #2 on: September 17, 2013, 06:27:44 pm »
Better to fit a clutch too strong than a clutch too weak.
If you think you might be running 330lb ft and a clutch who's torque rating is 400lb ft would last a lot longer than one with a rating of 350..
Offline DomBacon
« Reply #3 on: September 18, 2013, 10:50:51 am »
Well it'll only be for fast road use, doubt I'll take it on a track and I'm only going stage 2
Does anyone know, With a single mass flywheel does it make it sound like a tractor and rattle like anything?
Offline Pete R
« Reply #4 on: September 18, 2013, 11:42:28 pm »
Dom.
Give Andy a ring @ Cg Motorsport
