Author Topic: Lack of boost / hesitation at WOT  (Read 2983 times)
Offline bigmig95
  • -Receive: 50
« on: January 30, 2014, 05:05:27 pm »
Noticed recently the car hesitates and dosn't pull at wide open throttle, sometimes it's ok and sometimes it happens.  No real issues at part load.
Scan with VCDS comes up with.
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115     HW: 1K0 907 115
   Component: 2.0l R4/4V TFSI G00 0070
   Revision: --H01---    Serial number: VWZ7Z0E1497199
   Coding: 0403000318070160
   Shop #: WSC 00152 210 91233
   VCID: E3C313982282D506691-80B6
2 Faults Found:
008200 - Intake Manifold Flap; Bank 1
               P2008 - 001 - Electrical Malfunction - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 0
                    Fault Frequency: 11
                    Reset counter: 255
                    Mileage: 141050 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 09:30:07
             Freeze Frame:
                    RPM: 3375 /min
                    Load: 11.4 %
                    Speed: 47.0 km/h
                    Temperature: 61.0°C
                    Temperature: 14.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 14.224 V
012600 - Intake Manifold Runner Control
               P3138 - 008 - Regulation Deviation - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 0
                    Fault Frequency: 8
                    Reset counter: 255
                    Mileage: 141050 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 09:30:07
             Freeze Frame:
                    RPM: 3320 /min
                    Load: 11.8 %
                    Speed: 46.0 km/h
                    Temperature: 61.0°C
                    Temperature: 14.0°C
                    Voltage: 14.224 V
Readiness: 0000 0000
Prior to a scan I initially thought it was my DV which was rev G.  Replaced with the same model G and I still have the same issues.  Any ideas if the manifold flap / runners can stick and cause flow restriction at WOT ?
I've seen threads on these codes but didn't know if the running issues I'd experienced coul be attributed to the manifold runners flaps as sometimes these fault codes don't exactly point you in the right direction.
I've gone through the adaption process and it cleared it but then came back after a long run.
Anyone experienced these problems ?
Offline bacillus
  • -Receive: 453
Re: Lack of boost / hesitation at WOT
« Reply #1 on: January 30, 2014, 05:46:02 pm »
What spark plugs are you using?
Offline bigmig95
  • -Receive: 50
« Reply #2 on: January 30, 2014, 06:04:56 pm »
Will take a look.  VW replaced them last service 8k ago.
Offline bigmig95
  • -Receive: 50
« Reply #3 on: January 31, 2014, 08:50:18 am »
NGK BKR7EIX
Don't look too bad.  Cylinder 1 (1-4 L to R) looks a tad different to the others so I'll replace them all to try and eliminate issues in this area.  Still doesn't get rid of the manifold flap faults. Just wanted to try and link the flap fault to the issue and didn't know if anyone who'd had this fault had noticed this hesitation at WOT.
Offline nik nak
« Reply #4 on: June 29, 2014, 10:10:34 pm »
Hi i am having the same codes did you sort your car in the end?
Offline mk4gti-t
  • -Given: 61
« Reply #5 on: July 01, 2014, 08:41:55 am »
Sounds like the same issue i'm having. Flapper motor needs replacing i think..................
