Author Topic: Wheel bearings  (Read 1377 times)
Offline Rustybear
  • -Given: 243
Wheel bearings
« on: February 19, 2014, 08:38:06 pm »
Hearing a slight drone when driving that continues when in motion and not in gear.
I'm suspecting a wheel bearing, how much are they to do these days?
Got Pirelli p zeros on the back with 3m left so could it be these making the noise maybe?
Offline mw-wax
Re: Wheel bearings
« Reply #1 on: February 19, 2014, 08:42:22 pm »
Hi, it could be your tyres as they go out of shape on the back thats what happened to mine.
Offline Carpy25
Re: Wheel bearings
« Reply #2 on: February 19, 2014, 09:24:38 pm »
I had what I thought was rear bearing rumble and mine also turned out to be the tyres , common on mk3 so i'm told and common with bridgestones as well , with the tyres that low new rubber could be the cheapest option , if you can feel any play when jacked up
Rob
Offline Chris92
  • -Given: 33
Re: Wheel bearings
« Reply #3 on: February 19, 2014, 10:41:13 pm »
Yeah could be tyre noise. if you've got a jack lift the car and spin/feel for play in bearing I'd do all four just for good measure even if you think you know what corner it's coming for they can fool you easy when it comes to where you think the noise is coming from.
Offline Rustybear
  • -Given: 243
Re: Wheel bearings
« Reply #4 on: February 26, 2014, 09:50:12 pm »
Ok all sorted two new rear tyres = no noise and driving allot better  :happy2:
