Author Topic: Stage 2+ Edition 30 not making figures.....  (Read 3455 times)
Offline JigBake
« on: May 20, 2014, 08:20:34 pm »
My friend has a 56plate Edition 30 with 80k and has:
- APR fuel pump
- 3" decat down pipe
- Pipercross Panel filter
It only made 305bhp with a stage 2+ map and is being told that the low power output is down to coking of the valves and no catback. Im shocked at this. I really thought that it would have made more power than that.
My Edition 30 (only 30k) made 351bhp at stage 2+ and I had a full system, panel filter and fuel pump.
Any thoughts or opinions on what it could be, or whether his advice is correct?
I appreciate any help.
Cheers.
Offline mvb12
  • -Receive: 64
Re: Stage 2+ Edition 30 not making figures.....
« Reply #1 on: May 20, 2014, 08:22:55 pm »
didn't think you can go stage 2+ without the full exhaust system  :confused:
Offline metaljay
  • Scirocco R Owner
« Reply #2 on: May 20, 2014, 08:23:37 pm »
I thought the same, also should probably have a full induction kit, not just a filter.
Offline SurreyED30
« Reply #3 on: May 20, 2014, 08:24:01 pm »
56plate edition 30?? :confused:
Offline bacillus
  • -Receive: 453
« Reply #4 on: May 20, 2014, 08:24:11 pm »
The usual culprit is a boost leak somewhere so check dv and all hoses and connectors.
Offline skard
  • -Receive: 245
« Reply #5 on: May 20, 2014, 08:31:17 pm »
There are plenty of them...such as mine
« Reply #6 on: May 20, 2014, 08:32:34 pm »
Yeap, that's when they started.
Catback will add nothing but a bit of noise. Check the DV and pipes as mentioned.
« Reply #7 on: May 20, 2014, 08:33:22 pm »
Down pipe, HPFP & intake are the minimum prerequisites as far as I can remember.
« Reply #8 on: May 20, 2014, 08:39:45 pm »
Planning an intercooler?
Offline Markyed30
« Reply #9 on: May 20, 2014, 08:39:48 pm »
Nothing to do with no cat back I'm stage 1+ on standard system, Fuel pump and evoms and made 330 od bhp and 350lb of torque he should get an intake though
Offline JigBake
« Reply #10 on: May 20, 2014, 08:40:34 pm »
It wont be the lack of induction kit, my car flowed 350bhp with pipercross panel filter. Would the mapper of not picked up on the boost loss/leak? I will get him to check any ways, try to eliminate the problem.
Offline SurreyED30
« Reply #11 on: May 20, 2014, 08:43:02 pm »
I standard corrected   :notworthy: I thought the edition30 was 2007-2008 only.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #12 on: May 20, 2014, 08:55:25 pm »
As Mike said above the down pipe & sports cat or Decat is all that's required. The cat back section gives you about 2bhp
Saintsteve
« Reply #13 on: May 20, 2014, 09:57:53 pm »
That many?  :signLOL:
 :wink:
Offline GTI-Ross
  • Learning All The Time :)
« Reply #14 on: May 20, 2014, 10:10:26 pm »
If there is no boost leak, have you considered that the Dyno might be out or needs re-calibrating. You could always hop on another Dyno and see if the results are the same.
What tuner did you go with? are they a VAG specialist?
