Author Topic: Oil pressure.... Stop engine!  (Read 6281 times)
Offline b16mak
« on: June 08, 2014, 10:02:25 am »
Hi guys
I was stopped at the lights this morning and came to move off in first and the car just wouldn't move, I tried to turn engine off and on again to try move it and it just kept trying to start as if it's a low battery but wouldn't move. The error message on the display said: oil pressure stop engine! And had the oil symbol
I had topped up oil last week so it shouldn't be low and it hadn't flashed saying low oil level
I have had issues with the car needing regular water top up to the coolant. I topped up about 5 days ago and it have flashed low coolant since then.
At the mo I need to move the car as it's in a restricted parking bay before tomorrow am. Can someone please advise what I should do, I have recovery so will call them as soon as I'm done with work today
Mak
Re: Oil pressure.... Stop engine!
« Reply #1 on: June 08, 2014, 11:20:43 am »
common problem in the older gti is the oil pick up pipe in the sump gets blocked-thier is a thread about it on here
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
Offline Shaw
« Reply #3 on: June 08, 2014, 04:48:38 pm »
Sounds too late to me :/
If the car was turning over like the battery was dead it's possible there's damage. Check the engine oil and make sure it hasn't turned to tar :o
Don't run it again until you're confident the engine oil is ok and the oil pressure is good.
'07 Mk5 GTI Manual
Offline b16mak
« Reply #4 on: June 09, 2014, 11:08:48 am »
AA guy thinks its either the wiring loom or the injectors, I have taken it to garage will see...
Offline grey golfster
  • -Given: 79
« Reply #5 on: June 09, 2014, 12:17:44 pm »
Injectors!?!...wtf?
Thers AA guys, and AA recovery drivers.
One of my neighbours was the latter, and i wouldnt trust him to fuel my lawn mower properly, let alone mix 2-stroke for a strimmer!
Tow it. Do not run the engine!
Offline b16mak
« Reply #6 on: June 10, 2014, 11:40:52 am »
Fuel pump apparently! £450  to replace it :laugh: :laugh:, does that sound about right?
Offline xjay1337
  • -Receive: 377
« Reply #7 on: June 10, 2014, 11:47:30 am »
No..... you can buy an uprated HPFP for that...
Why is it fuel pump if it's an oil pressure problem? unless that's just because the car was cranking for ages and didn't start, which if that's the case is expected and normal.
If it's a fuel pump buy a used HPFP for like £120 and fit it yourself.
Offline b16mak
« Reply #8 on: June 10, 2014, 11:52:26 am »
Yea 450 includes diagnostic fee.
I think the oil pressure light only comes on when the car is cranking for ages as you say and then it flashes with the oil symbol/says low oil pressure stop engine.
I am in NW london can anyone recommend anything please?
Offline b16mak
« Reply #9 on: June 11, 2014, 08:59:07 am »
Is replacing a fuel pump an easy job? As I don't have a clue.... Or can somebody recommend someone
Thanks very much!!!
Offline DamoP
  • -Receive: 115
  • 2007 Edition 30 number 1242
« Reply #10 on: June 11, 2014, 12:52:01 pm »
Thanks very much!!!
detailed guide and pics
http://www.golfmkv.com/forums/showthread.php?t=129924
MDI Armrest & Glovebox kits
Armrests, cloth and leather
Offline xjay1337
  • -Receive: 377
« Reply #11 on: June 12, 2014, 09:06:08 am »
That's for the in tank**** fuel pump?
The HPFP is a lot easier.. it's like 5 bolts.
« Last Edit: June 12, 2014, 09:57:19 am by xjay1337 »
Offline DamoP
  • -Receive: 115
« Reply #12 on: June 12, 2014, 09:23:18 am »
That's for the intake fuel pump?
just googled fitting a fuel pump  :signLOL:
Offline Shaw
« Reply #13 on: June 12, 2014, 11:16:24 am »
Am I missing something. Why are you replacing the hpfp to cure low oil pressure?
'07 Mk5 GTI Manual
Offline xjay1337
  • -Receive: 377
« Reply #14 on: June 12, 2014, 11:57:52 am »
If you read it , the car isn't starting
Extended cranking causes oil pressure light to go on.
