Author Topic: Boost feed needed!  (Read 1959 times)
Offline J6JCC-GTI
Boost feed needed!
« on: June 18, 2014, 07:56:31 pm »
I need a boost feed for my BCS powervalve, do I need a boost tap that attaches to the PCV pipe?
I've been trying to search on the forum but I can find anything!
Insta: jclarke2792
Re: Boost feed needed!
« Reply #1 on: June 18, 2014, 08:00:25 pm »
Yeap you'll need a fitting kit.
My BCS Powervalve TBE and my boost gauge both run of a multi tap from Forge that attaches to the PCV.
There's a few around, from APR, 42 Draft Designs and Forge. This is the one you want. Forge.......
~~ Clicky here ~~
And the fitting instructions.....
~~ Clicky here ~~
« Last Edit: June 18, 2014, 08:03:35 pm by MC71 »
Offline J6JCC-GTI
« Reply #2 on: June 18, 2014, 08:21:02 pm »
Thank you very much that's perfect :happy2:
Is the forge one the best to get? I don't like the look of the little blanking screws?
Insta: jclarke2792
« Reply #3 on: June 18, 2014, 08:35:50 pm »
It's as good as any other TBH, plus its British manufactured so its a win win. Multi tap screws are fine, if you add anything else that requires a feed you'll be glad of a simple screw to remove. My forge fitting kit has been on for ages with no probs at all.
Offline J6JCC-GTI
« Reply #4 on: June 18, 2014, 08:46:14 pm »
Just ordered a forge one!
Thank you very much :happy2:
Insta: jclarke2792
« Reply #5 on: June 18, 2014, 08:51:21 pm »
^^^^ No worries.   :drinking:
