Author Topic: wheel help?  (Read 2018 times)
Offline golfgti10
wheel help?
« on: June 30, 2014, 09:32:01 pm »
I currently have 18'' et42 speedline reps and centre core of 66.6mm so im using that spigot rings, but the car is lowered 30mm on the h&r springs and is catching just on the arch screw
if I change to 8j et43 18s centre bore 57.1 so no spigot ring needed will this bring it in more than the wheels I currently have so I can stop it catching on the arch?
help needed
Offline jaffa
  • -Receive: 44
Re: wheel help?
« Reply #1 on: June 30, 2014, 09:40:00 pm »
only by 1mm offset changes how the wheel will sit not the centre bore  :happy2:
do the arch screw mod and you will get rid of the rubbing
im assuming you running 225/40/18?
Offline golfgti10
Re: wheel help?
« Reply #2 on: June 30, 2014, 09:44:41 pm »
yeah im running 225/40/18, will the 8j not do nothing?
also whats the screw mod
Offline jaffa
  • -Receive: 44
Re: wheel help?
« Reply #3 on: June 30, 2014, 09:57:21 pm »
http://golfmkv.com/forums/showthread.php?t=10909&highlight=arch+screw+mod
Specs of the wheels are fine you just need to do the screw mod and you will be free of rubbing
A lot of people on here run BBS VZ 18x8 et44 and do the screw mod and are fine  :happy2:
Re: wheel help?
« Reply #4 on: June 30, 2014, 10:01:47 pm »
Screw mod.
Remove the arch liner screw (it's the one at the top), push the arch liner inside the arch rim, bend the bit of metal that the screw was screwed into in a bit which will stop the liner coming back out and job done.
If you want to see how much poke your going  to get with various size wheel/offset combos use  this site, just put all the info in and Bobs your uncle....
http://www.willtheyfit.com
Offline golfgti10
Re: wheel help?
« Reply #5 on: June 30, 2014, 10:05:26 pm »
so the higher the et the more it will poke out right?
Offline jaffa
  • -Receive: 44
Re: wheel help?
« Reply #6 on: June 30, 2014, 10:07:58 pm »
other way round  :signLOL:
the lower the offset the closer to the arch its going to get, iv been trying to teach my brother this for years  :signLOL:
Re: wheel help?
« Reply #7 on: June 30, 2014, 10:12:12 pm »
Use that calculator with 2 wheels of the same width and different offset and you will see.
Offline golfgti10
Re: wheel help?
« Reply #8 on: June 30, 2014, 10:20:44 pm »
whats the et on standard edition 30 wheels then?
Re: wheel help?
« Reply #9 on: June 30, 2014, 10:29:44 pm »
18x7.5 ET51 for the Pescara's.
My BBS VZ's and TD 1.2's are both 18x8 ET44 so have 13mm more poke over my OEM Pescara's (for reference).
« Last Edit: June 30, 2014, 10:32:09 pm by MC71 »
Offline golfgti10
Re: wheel help?
« Reply #10 on: June 30, 2014, 10:31:58 pm »
is that what you was running as I cant find any pescaras for sale :(
Re: wheel help?
« Reply #11 on: June 30, 2014, 10:34:04 pm »
My OEM wheels were Pescarsa's but I needed more room for a BBK so got the 2 sets I mentioned in my previous post. Also a bonus of a much better stance. Look in my build thread for pics.
edit: In case I wasn't clear.....Pescara's are the OEM wheels for the Edition30!  :happy2:
« Last Edit: June 30, 2014, 10:36:16 pm by MC71 »
Offline SL4VE
Re: wheel help?
« Reply #12 on: July 01, 2014, 01:02:44 pm »
arch mod is a new VAG pet hate for me
