Author Topic: DV G or D  (Read 2537 times)
Offline Bennz
DV G or D
« on: July 16, 2014, 02:45:43 am »
Seen many threads on this topic. Mine currently is G, however decided to get it checked and possibly replace it.
I know the difference between G and D, however I heard some say D leaks boost.
How accurate is that? Overall is D worth it or should I stick with G ?
I'm running stock parts and don't plan to upgrade.
Appreciate your suggestions.
Offline betty_swollox
  • -Receive: 29
Re: DV G or D
« Reply #1 on: July 16, 2014, 03:20:49 am »
I really don't get this thread
you know the difference between them and you have also stated that you have heard that the rev D leaks boost....
........so why don't you just get the rev G?!?!?! :confused: :confused: :confused:
2010 Leon CUPRA
BCS Powervalve Exhaust
Revo Ceramic Intake
APR Stage 2
Offline Bennz
Re: DV G or D
« Reply #2 on: July 16, 2014, 04:08:49 am »
Because I want to know others opinion as well . I hear some say D is okay and no leaks but few say otherwise.
And it's not like I can try before buying lol
Doesn't hurt to ask for opinions :)
Offline Sug
Re: DV G or D
« Reply #3 on: July 16, 2014, 05:45:21 am »
Manual or DSG?
EDITION 30 GONE, MK6 R GONE........AUDI 8V S3.....Stock for now
  • -Receive: 29
Re: DV G or D
« Reply #4 on: July 16, 2014, 06:14:05 am »
2010 Leon CUPRA
Revo Ceramic Intake
APR Stage 2
Offline Bennz
Re: DV G or D
« Reply #5 on: July 16, 2014, 07:13:35 am »
DSG
Offline greygti
Re: DV G or D
« Reply #6 on: July 16, 2014, 07:35:40 am »
G
Offline SurreyED30
Re: DV G or D
« Reply #7 on: July 16, 2014, 07:38:55 am »
I'm sure there's a newer rev now .... P I think? I've seen it somewhere in here It's £65 but could be better than G. Fit a rev C just to get under some peoples skins  :popcornsoda:
Offline Bennz
Re: DV G or D
« Reply #8 on: July 16, 2014, 07:59:24 am »
Rev P? What's new with that ?
Offline Nodz
  • -Given: 73
  • -Receive: 103
Re: DV G or D
« Reply #9 on: July 16, 2014, 08:22:38 am »
D can leak from factory as the piston type does not seal as well as the ones with the rubber diaphragm especially on big power cars. Just bang a g in and check at every service and replace when needed
Re: DV G or D
« Reply #10 on: July 16, 2014, 08:45:23 am »
G end off.
D DOES LEAK, it will as its a piston whereas G is a diaphragm so won't, it may split but will most likely not leak. Many of us with Stage 2+ K04's are running the G with no problems at all, holds boost way better.
Please delete this USELESS thread before the admin ban you and delete your account.  :happy2:
Its basically a D with a cage thingy IIRC so avoid that one.
Re: DV G or D
« Reply #11 on: July 16, 2014, 09:45:20 am »
Not again........
