Author Topic: Accessing the MFD on highline clocks without a MFSW?  (Read 8770 times)
Offline Georrge
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,93533.msg937034.html#msg937034
« on: September 22, 2014, 09:33:33 pm »
I had highline clocks fitted recently, I believe they end in 972 from memory. I don't have a MFSW, but it is something I will get in the future, preferably a MK6 one  :smiley:
But is there a way to access the other menus with the stalk? I can obviously toggle between average MPG, miles left inb tank etc with the up down button, and I've tried holding them down to see if that does anything but no luck.
Thanks!  :happy2:
Instagram @george_kersh
Offline xjay1337
  • -Receive: 377
Re: Accessing the MFD on highline clocks without a MFSW?
« Reply #1 on: September 22, 2014, 09:57:01 pm »
Yes you can...
You either press and either the up or down button or press the button underneath the stalk (set up). I can't remember which but its the ssme set up i had on my old TDI.
Offline Georrge
« Reply #2 on: September 23, 2014, 12:37:33 pm »
I just tried all of that and had no luck. I tried just a simple press, I also tried a press and hold. Here is a quick video demonstrating:
Offline xjay1337
  • -Receive: 377
« Reply #3 on: September 23, 2014, 04:19:38 pm »
Very odd. It was holding the up or downbutton on the end that did it.
Maybe your cluster PN is wrong for use with indicator stalk
Offline th3_f15t
  • -Receive: 183
« Reply #4 on: September 23, 2014, 04:24:32 pm »
I've had highline clocks fitted as standard and only ever switched between average MPG, range ect. I'm going to have a play tonight and see, as I don't (nor ever have had) a multifunction steering wheel...
Offline Georrge
« Reply #5 on: September 23, 2014, 05:06:49 pm »
That's what I thought I had read previously! Oh well it's no big deal really as I will one day get a mk6 mfsw.
Do you think changing my stalk would fix the problem?
Let me know if you can access it :)
Offline th3_f15t
  • -Receive: 183
« Reply #6 on: September 23, 2014, 05:43:43 pm »
What are the other menus I should be able to access and how do I do it? Sorry for the very stupid question, never come across this before now.
Offline Georrge
« Reply #7 on: September 23, 2014, 06:14:45 pm »
This shows some of the menus
http://www.myturbodiesel.com/wiki/multifunction-display-mfi-or-mfd-faq-and-menu-settings-mk5-mk6/
Offline th3_f15t
  • -Receive: 183
« Reply #8 on: September 23, 2014, 06:17:50 pm »
How the hell did I not know of these toys in my car before now?! Where's my keys..? :laugh:
Offline Georrge
« Reply #9 on: September 23, 2014, 06:40:46 pm »
Haha, let me know if you can access it! There is lots of little things you can change with the menus  :happy2:
Offline th3_f15t
  • -Receive: 183
« Reply #10 on: September 23, 2014, 06:49:38 pm »
Need to consult the hand book and work out how to get to these menus... I'm going to hold various buttons and see what happens.
Offline Georrge
« Reply #11 on: September 23, 2014, 06:54:44 pm »
Just watch the video I posted earlier on this thread, one of those methods should work. But doesnt for me as I retro fitted them
Offline th3_f15t
  • -Receive: 183
« Reply #12 on: September 23, 2014, 07:01:42 pm »
Yeah, mine worked by just pressing on one of the end buttons on the stalk (like you did in your video). Does it need setting up with VCDS then if your retro fit?
Offline Georrge
« Reply #13 on: September 23, 2014, 07:04:36 pm »
I'm glad yours is ok! Enjoy your new features haha. Yeah it needs coding, it was coded correctly but someone but as mentioned earlier on, my stalk isn't the correct [air with the clocks.
Offline Rukz
« Reply #14 on: February 23, 2015, 09:42:55 pm »
Hi George,
Sorry to bring this ancient thread back up, but wondering if you found a solution to this issue? I'm having the exact same issue, I recently upgraded from midline to 972 Highline clocks, I don't have mfsw and can't access mfd via my stalk driving me insane.
Tornado Red | MK5 | GTi | DSG
