Author Topic: Front wiper arms - removal  (Read 11590 times)
Offline bluo
« on: November 18, 2014, 08:49:49 am »
Hi guys,
I've looked all over, possibly not hard enough and if so apologies in advance!
How do I remove my front wiper arms, is there a specific tool or technique to use?
It's an 07 gti...
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
Re: Front wiper arms - removal
« Reply #1 on: November 18, 2014, 01:31:24 pm »
Are you talking about the full arm or the wiper blade?
If it's the arm as I suspect.
Pop the hood, take off the circular cap on each arm with a flat head screwdriver.
Wiggle, WD40 and use a good bit of patience to get the wiper arm off.
If you haven't removed them before they're likely frozen on and will take a few minutes.
Don't prize them up or you risk damaging the glass or bending the metal.
Offline xjay1337
  • -Receive: 377
« Reply #2 on: November 18, 2014, 01:34:30 pm »
think it's a 13mm socket the nut should come off quite easily.
Might be hard to get off... where the wiper arm curves up just give it a few taps with your hand.
Offline paulw123
  • -Receive: 47
« Reply #3 on: November 18, 2014, 04:40:37 pm »
lots of wiggling on end of arm should do it, oh and patience
Offline Andygtiiii
« Reply #4 on: November 18, 2014, 06:36:41 pm »
Wiper remover tool £5 of ebay
Offline bluo
« Reply #5 on: November 18, 2014, 06:43:13 pm »
Ok so I've done all of that and nothing!
The arms were off about two months ago as the scuttle tray wasn't sitting in correctly so got the dealer to sort that out and put the arms back.ever since the wiper blade on the passenger side catches the rubber to the lowest part of the a pillar- almost like it's too long!
Never had that before and the same blades are on.
Just want to adjust the arm position slightly but really struggling to get them off!!
Offline bluo
« Reply #6 on: November 18, 2014, 07:37:10 pm »
Yeah I got one of them and the plastic handle just started turning once there was some tension... Should have bought a more expensive one!
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #7 on: November 19, 2014, 11:22:45 am »
It's hard to explain but I was in the same situation.
If you bend the lower part of the arm, the closest section to the motor so that it's parallel with the window. This takes the strain off.
Now use loads of WD40 and get wiggling.
Another one is to turn wipers on and leave them in the up position. Tackle it the same as above and repeat.
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #8 on: November 19, 2014, 02:05:59 pm »
If you have time it seems there are on ebay cheap windscreen wiper removal tools like this:
GL!
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
« Reply #9 on: November 19, 2014, 02:44:01 pm »
GL!
That's what I used when I replaced the wiper motor, makes the job easy. :happy2:  Cheap too.
Offline bluo
« Reply #10 on: November 19, 2014, 10:17:47 pm »
GL!
Got one of them, that plastic handle just started turning under tension - must have been a dud!!!
Offline doylebros
  • -Receive: 310
« Reply #11 on: November 19, 2014, 10:24:23 pm »
Just bin the plastic nut - use another nut against the original nut as a locking nut - use a spanner or socket and just apply force and the arms will give!
Offline bluo
« Reply #12 on: November 19, 2014, 11:57:13 pm »
Genius! I'll give that a go over the weekend and report back - thanks.
