Author Topic: HID Kit?  (Read 9025 times)
Offline anderson9
HID Kit?
« on: November 26, 2014, 09:10:15 pm »
Best HID kit to use, anybody used or got one at the minute ?
Offline edd30
Re: HID Kit?
« Reply #1 on: November 28, 2014, 01:28:24 pm »
They don't work very well with Mk5 standard reflector headlamps. Very poor beam pattern, to get more light on the road, you'll be creating a lot of glare towards other road users. Even if you don't care - the result is still crap. Automatic membership in chavland.
Other options
1) Retrofit original xenon hids.
2) Fit and align proper hid projectors in your current units.
3) Fit Hello or Depo projector lights for H7 halogens, use HID H7 kit.
4) Fit brighter H7 bulbs.
1 and 2 give you the best light pattern. 1 is expensive and needs coding. About £400 2nd hand including Kufatec adaptor.
2 requires some work with fitting, but can be better than oem. Stick with known makes, like Morimoto. Use a decent H1 HID kit with it, total about €230.
3 Not as good as 1 and 2. Beam pattern ok, not perfect. £300 new.
4) Cheap, but better than using a H7 HID with a reflector lamp.
Re: HID Kit?
« Reply #2 on: November 28, 2014, 05:59:50 pm »
I had them in my standard lights even with the h7r bulbs in they were dazzling on going traffic so i took them out and replaced them with ring extreme h7 bulbs
Offline robmcclel
Re: HID Kit?
« Reply #3 on: December 23, 2014, 04:43:27 pm »
try "ultra" bulbs, they are standard H7 bulbs but shine white like xenon's otherwise do it properly and go for retrofitted oem xenon's
Offline liam
Re: HID Kit?
« Reply #4 on: January 02, 2015, 04:08:51 pm »
I just bought some white bulbs, same effect and a lot cheaper! sure you can get full beam, high beam and LED side light bulbs for under £50 for all of them.
Offline anderson9
Re: HID Kit?
« Reply #5 on: January 04, 2015, 07:04:19 pm »
Have you any pics ?
Offline K1NGY14
Re: HID Kit?
« Reply #6 on: January 04, 2015, 10:21:38 pm »
Have you any pics ?
+1
Offline liam
Re: HID Kit?
« Reply #7 on: January 05, 2015, 05:31:31 pm »
Have you any pics ?
+1
I'll take some tonight, only got headlights in at the moment but you will see the colour difference.
Offline paulw123
  • -Receive: 47
Re: HID Kit?
« Reply #8 on: January 05, 2015, 05:41:14 pm »
Only put a HID kit into projector headlights please....or the dazzle police will be after you  :fighting: :fighting:
Unfortunately no bulbs will be as bright as a HID kit.
Offline anderson9
Re: HID Kit?
« Reply #9 on: January 21, 2015, 02:14:42 pm »
What's the best HID kit to buy ?
Offline robmcclel
Re: HID Kit?
« Reply #10 on: January 22, 2015, 10:27:19 am »
Best bet is to fit an oem set but otherwise you want something like this if you want to fit an aftermarket xenon kit as these take standard bulbs.
http://www.ebay.co.uk/itm/VW-Golf-MK5-2003-2009-R32-Gti-Style-Black-Projector-Head-Lights-Lamps-Depo-Pair-/301204859556?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4621356aa4
Plus make sure you get a canbus error free one if you do choose the aftermarket option.
Offline boardyuk
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,88307.0.html
Re: HID Kit?
« Reply #11 on: January 22, 2015, 01:53:09 pm »
I've just bought a set of these and they arrived yesterday. Spent last night fitting this kit from HIDS Direct (5000k version) http://www.hids-direct.co.uk/h7-35w-ultra-slim-35w-hid-xenon-conversion-kit/. I think a few others on here have used this kit with different colour temp bulbs.
I'm hoping to get them fitted to my car at the weekend along with a few other bits but even out of the car they look great. I haven't managed to get the HID kit fired up yet but can't wait to see what it looks like!
Offline paulw123
  • -Receive: 47
Re: HID Kit?
« Reply #12 on: January 22, 2015, 04:33:33 pm »
says this kit comes with mk5 golf bulb holders as well, what is the advantage of that then?
Offline boardyuk
Re: HID Kit?
« Reply #13 on: January 22, 2015, 04:39:48 pm »
That is a really good question as I couldn't actually get them to fit the Depo projectors  :signLOL:
I think the bulb holders are for fitting the kit into the stock reflector units, which personally I refuse to do anyway  :sick:
Offline paulw123
  • -Receive: 47
Re: HID Kit?
« Reply #14 on: January 22, 2015, 04:49:23 pm »
absolutely agree with you on HIDs in reflector headlights  :mad:
so do you still have to drill a 1"hole in the back of the depo's to fit the H7 hid bulbs in?
