Author Topic: MK5 Golf R32 lowered suspension settings  (Read 2924 times)
Offline sumtingwong
  • MK5 R32 DPB DSG
« on: February 14, 2015, 12:00:08 pm »
Hi guys,
At the tyre shop.
What's the settings for lowered r32? H&R springs, -25 front and -20 back?
MK5 R32 DPB DSG
Offline sumtingwong
  • MK5 R32 DPB DSG
Re: MK5 Golf R32 lowered suspension settings
« Reply #1 on: February 14, 2015, 12:13:08 pm »
Bump as I'm at the shop
MK5 R32 DPB DSG
Redemption
« Reply #2 on: February 14, 2015, 01:31:39 pm »
Same as the stock settings as far as I know.
« Reply #3 on: February 14, 2015, 02:10:51 pm »
Settings?
Redemption
« Reply #4 on: February 14, 2015, 02:29:56 pm »
Settings?
I assume he means Camber, Toe etc.
Offline sumtingwong
  • MK5 R32 DPB DSG
« Reply #5 on: February 14, 2015, 02:54:37 pm »
Settings?
Correct, I would ask on R32oc but it's not working on my phone.
Any help would be great.
MK5 R32 DPB DSG
Redemption
« Reply #6 on: February 14, 2015, 03:18:03 pm »
As I mentioned above, the stock settings should be fine. If it's a Hunter Alignment machine then it'll have an acceptable range that each setting has to fall within. I've got those ranges if you want them as mine was aligned yesterday. :smiley:
« Last Edit: February 14, 2015, 03:21:43 pm by Redemption »
Offline sumtingwong
  • MK5 R32 DPB DSG
« Reply #7 on: February 14, 2015, 03:28:19 pm »
I just rang the place up and the manager said that if the car has been lowered than the original settings has been changed, therefore the original specs won't work :(
MK5 R32 DPB DSG
Redemption
« Reply #8 on: February 14, 2015, 03:33:27 pm »
You've not lowered it much so you still need to aim for the factory settings range. What becomes an issue is when you slam it and it's so low that you run out of adjustability on the OEM parts and have to start adding camber plates etc.
« Last Edit: February 14, 2015, 03:35:05 pm by Redemption »
Offline sumtingwong
  • MK5 R32 DPB DSG
« Reply #9 on: February 14, 2015, 07:55:56 pm »
I tried asking if they can do anything, but the guy is saying that I need they specs in order for them to do it.
Ill try asking back on the oc since I am home now.
Its a real shame that the forum dont work on my phone, keeps saying error when I load the damn page :(
MK5 R32 DPB DSG
Offline Horatio
  • -Receive: 39
« Reply #10 on: February 14, 2015, 09:13:05 pm »
Had mine done at wheels in motion a while ago, lowered 25mm H&R springs on standard shocks. These guys are brill.
