Author Topic: Another oil level thread sorry.  (Read 2971 times)
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« on: June 12, 2015, 03:42:07 pm »
When i dropped the sump a couple of weeks ago. I added 5L of oil. This had the oil level on the max maybe a smidge over. Checked the oil today its way over max. Cant even work out where the level is. I extracted about 400ml and its dead on the max again.
How much oil should fill it after dumping the oil??
05 | Tornado Red | DSG
Offline th3_f15t
  • -Receive: 183
Re: Another oil level thread sorry.
« Reply #1 on: June 12, 2015, 03:44:11 pm »
A full dry engine takes just over 5 litres if I recall correctly, so if there's left over oil from a change then about 4.5 litres fills it right up for me usually.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #2 on: June 12, 2015, 03:53:37 pm »
Thanks mate I probably put too much in. I did triple check the oil level though. With what i removed today that leaves 4.6l sounds about right.
Offline th3_f15t
  • -Receive: 183
« Reply #3 on: June 12, 2015, 04:17:08 pm »
Did you change the filter at the same time as the sump? I think that absorbs a few hundred millilitres in the first few miles as well so takes a little while for the true oil level to be found.
Offline Matthewsimone
  • -Receive: 39
« Reply #4 on: June 12, 2015, 04:26:06 pm »
Mine recently used 4.4l with filter changed too  :happy2:
« Reply #5 on: June 12, 2015, 04:58:26 pm »
What the level on the PolarFIS?
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #6 on: June 12, 2015, 07:09:10 pm »
I changed the filter as well.
I did not know PolarFIS shows the oil level.
Tried to add it to one of the screens. But i'm getting identifying available parameters.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #7 on: June 12, 2015, 08:15:05 pm »
that was a pita. Pulled the polarfis out tried to update it. It shows damaged polar and would not fix. Don't know if its due to not finding the correct lead. Or using vmware on a mac. Put it back in anyway and i was able to change the parameters.
Oil level 67.5???
« Reply #8 on: June 12, 2015, 09:04:14 pm »
Ok. Mine reads about 60-65.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #9 on: June 12, 2015, 09:25:07 pm »
And this is with oil at the max mark on dip stick??
« Reply #10 on: June 12, 2015, 09:40:20 pm »
50-75% up the hatched part. Polar fis reads 55-65 depending.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #11 on: June 12, 2015, 11:35:11 pm »
So you don't have it at max? Whats the recommended level?
« Reply #12 on: June 13, 2015, 12:08:27 am »
Above min and below max.  :smiley:
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #13 on: June 13, 2015, 12:26:03 am »
It was loosing a bit of oil so thought it best to max it out. Will keep an eye on it.
Offline th3_f15t
  • -Receive: 183
« Reply #14 on: June 13, 2015, 09:24:17 am »
As long as it's not over the maximum mark you'll be fine. I usually top mine up to the maximum mark as well to allow for the oil that gets burnt off anyway. It's when it's over then you start to excessively burn oil and also increase oil pressure which can lead to all sorts of problems.
In theory, if your oil leak is worse when the oil pressure is higher, maybe keeping it under half full is better for your engine until you resolve the leak? Just a thought...
