Author Topic: Fitting number plate surrounds to smooth grill  (Read 1246 times)
Offline markos
« on: July 02, 2015, 08:45:29 pm »
Anyone know the best way to do this? I carefully shaped the surround with pressed plate inside to suit the slight curve on the mk5's smooth grill and attached with number plate adhesive strips but came out 30mins later to see it had come away on the sides because of the flex. What's the best way to fit these? I've heard suggestions of magnets and suckers but can't see them being strong enough for everyday use?!
Offline Johnsy
Re: Fitting number plate surrounds to smooth grill
« Reply #1 on: July 02, 2015, 09:38:03 pm »
Iv done this on my Leon, I removed all the the old sticky tape first made sure the surface was clean.
Fixed my plates using 2x screws in the middle and used 3M VHB double sided sticky tape. they ain't budged
Offline th3_f15t
  • -Receive: 183
« Reply #2 on: July 02, 2015, 09:39:26 pm »
I used magnets on my pressed plate to hold it to the car, it survived thousands of miles without even moving about. Remember, each little magnet holds a few kg of weight, so a single kilo help with several magnets goes no where.
I was sceptical when I did it, but it really works well. And it means you can remove the plate at shows and then put it back on before driving home with no fuss or tools needed.
Offline markos
« Reply #3 on: July 02, 2015, 10:01:38 pm »
Can you remember what kg pull they were? Any bits of electricals around there to worry about mate?
Offline markos
« Reply #4 on: July 02, 2015, 10:02:16 pm »
Thanks but want to avoid drilling holes in the grill
