September 19, 2026, 08:10:53 am
All Things Mk5
Mk5 General Area
radiator not working
Topic: radiator not working (Read 1254 times)
Jayy26
Always Involved
-Given: 10
-Receive: 4
July 24, 2015, 04:56:56 pm »
my radiator fans dont come on now and when the car is stationery for a while with the engine on, my coolant light comes on but if i switch it off it bubbles out..so i have to take it for a small drive then its fine, Ive checked fuse 38
xjay1337
Just look at my post count
-Given: 15
-Receive: 377
My Ride:
Re: radiator not working
Reply #1 on:
July 24, 2015, 05:23:22 pm »
Have you checked the relays? There's some which are quite common for blowing.
Click for build thread
Stage 2 GTI Purple Scene Queen
221bhp/365lbft TDI build
Detailing Guide
Wheel Fitment Guide
th3_f15t
-Given: 66
-Receive: 183
My Ride:
Reply #2 on:
July 24, 2015, 05:56:43 pm »
I can't remember if you can use a voltmeter go test the fans in with, but that's worth reading up on too.
Jayy26
Always Involved
-Given: 10
-Receive: 4
Reply #3 on:
July 24, 2015, 08:03:25 pm »
relay 1 gets quite hot tbh ? i cant be bothered with replacing so many parts to find a solution ha
was going to get my mate to pop and see if his vcds will run the fans but will that let me know any better?
th3_f15t
-Given: 66
-Receive: 183
My Ride:
Reply #4 on:
July 24, 2015, 09:38:35 pm »
It may tell you what is not working, but chances are it'll just say the fans aren't operating like they should and you'll have to fault chase regardless. Relays shouldn't get hot really, that to me is a sign it's faulty.
Jayy26
Always Involved
-Given: 10
-Receive: 4
Reply #5 on:
July 24, 2015, 10:01:54 pm »
ive tried switching the relays and there doing the exact same..
the codes did go but came back..also my car refused the vcds to start the fans
Ill post my fault codes up when he sends them across
th3_f15t
-Given: 66
-Receive: 183
My Ride:
Reply #6 on:
July 25, 2015, 08:57:48 am »
Have you checked that the fans can actually rotate in the housing but turning them by hand?
Jayy26
Always Involved
-Given: 10
-Receive: 4
Reply #7 on:
July 28, 2015, 12:54:20 pm »
yeh the fans are very free mate
All Things Mk5
Mk5 General Area
