Author Topic: The ultimate Dyno Graph thread  (Read 378717 times)
  • -Receive: 453
Re: The ultimate Dyno Graph thread
« Reply #285 on: March 24, 2012, 10:01:33 am »
So which RS4 valve should I get - B7?
This.  :smiley:
  • -Receive: 453
« Reply #286 on: March 24, 2012, 10:19:03 am »
So you ED 30 people do have to upgrade your hpfp as well as opting to add the RS4 valve, correct?
The addition of rs4 valve is optional when running a map that requests 130 bar and you should already have an uprated hpfp to provide the requested 130 bar.
« Last Edit: March 24, 2012, 10:23:56 am by bacillus »
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #287 on: March 24, 2012, 03:59:15 pm »
OK, thanks. I have the hpfp, but I don't have the RS4 valve. Should I log data and check if needed, or just go ahead with the rs4 valve install. Also, which lpfp should I replace the in-tank pump with if needed?
Offline 56OctyVRS
  • -Receive: 72
« Reply #288 on: March 24, 2012, 05:15:17 pm »
The lpfp will be fine as standard.
  • -Receive: 453
« Reply #289 on: March 24, 2012, 07:37:56 pm »
I would just change the valve.
Your in tank pump should be able to cope if it's ok atm as the valve just makes your hpfp work a little harder.
Offline ukdub
« Reply #290 on: March 24, 2012, 09:22:00 pm »
Spot on
Some standard valves crack open too soon ie at 120-125 bar when the standard valve should be good to 130 bar.  Therefore your map could be requesting 129.9 bar and your standard valve crack open too early and not make the requested fuel rail pressure required/requested by your map. Consequence of this happening? Probably pulling timing/boost and reducing power.
The RS4 valve will crack open at 136 bar, so making your 129.9 bar requested fuel pressure possible.
« Last Edit: March 24, 2012, 09:33:36 pm by ukdub »
Laser Blue with K04 power, APR hardware controlled by REVO 2+ software
Chassis by KW V3's, Whiteline and a hint of PRO race 1.2's
Brakes by Brembo 4 pots
Offline R-tech-Nick
  • -Receive: 30
    • R-Tech Performance Tuning
« Reply #291 on: March 24, 2012, 09:36:36 pm »
+1  It allowed me to run higher rail pressure map upto 135bar 4000rpm onward, which gave me a better combustion and allowed a small window for more timing advance at the top end.
01455 617233
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #292 on: March 25, 2012, 10:17:43 pm »
Thank you all, ordering the rs4 valve now ;] Can't wait!
Offline N13SCB
« Reply #293 on: April 03, 2012, 07:41:28 pm »
Budget Remap
ITG maxogen induction kit
Slowly progressing. . .
« Reply #294 on: April 04, 2012, 10:38:58 am »
Offline mark53
« Reply #295 on: April 04, 2012, 10:48:36 am »
Revo Stage 2 + 363BHP  345LB/FT
Offline danishmkvgti
  • -Given: 243
  • -Receive: 155
« Reply #296 on: April 04, 2012, 12:59:13 pm »
Am i correct in reading your torque to be 430nm Mike?  :confused:
You've lost 90nm  :surprised:
Over the top mod list ;o)
« Reply #297 on: April 04, 2012, 01:18:22 pm »
hmmm, not sure after being without the car for so long its hard to say if the butt dyno agrees but I wondered if chaanging from 2.75" Miltek to 3" BF w/de-Cat would be enough for such a torque drop
  • -Given: 243
  • -Receive: 155
« Reply #298 on: April 04, 2012, 01:31:02 pm »
I've had 3" since i went K04, so mine's making the 367bhp and 517nm on 3", do you know precisely what APR has changed?  :smiley:
Offline Janner_Sy
  • -Receive: 113
« Reply #299 on: April 04, 2012, 01:34:20 pm »
your comparing two completely different dynos so you have to take it all with a pinch of salt.
For example stage 2+ REVO cars on JKMs DD rollers rarely see over 300lbft.  Take them to another dyno and they'll see 380lbft!!!
