Author Topic: How to, Midline to highline retrofit  (Read 106358 times)
Offline Antvw
Re: How to, Midline to highline retrofit
« Reply #60 on: January 13, 2013, 05:41:41 pm »
got my 973b clocks fitted in my 07 tdi yesterday....
only major issue that i can see is whether you have VDO or Visteon which seem to be harder to rewrite...
anyway kalu can sort them out...
great upgrade!!!
Done one yesterday for a forum member, as you say a great upgrade
That was me! Cheers eddie!
Offline kalu
MK6/Scirocco Clocks in MK5
« Reply #61 on: January 13, 2013, 07:45:00 pm »
Just fitted a set of BAP Highline Scirocco R clocks in a MK5 R32. Properly adapted with working Immo :)
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #62 on: January 13, 2013, 08:29:05 pm »
Good work Aftab :notworthy:
I supplied these and can get others
PM me for a price
Cluster and Key coding
Location Great Yarmouth
Offline Redgtr
« Reply #63 on: March 05, 2013, 07:26:33 am »
In need of help please guys
I currently have 1k0920 951 b.  clocks in my golf tdi,need to change them as the fuel gauge has packed up so would like to upgrade to highline .could you tell me the parts I need and how to code hem all to my car
I have cruise control already but no multi function wheel or mfa
I live in South Wales
Any help would be great cheers jay
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #64 on: March 05, 2013, 08:27:47 am »
You can fit any diesel clocks from 2004 - 2009
1K092097* (* =) 1,2,3 or 4
You would require the stalk
Offline Shanny
« Reply #65 on: August 07, 2013, 03:28:47 am »
Hi, I have a golf 54 plate gt tdi, I do not know the number of my existing clocks, but I have purchased r32 clocks which end in 972 F
Will these fit in my car. The clocks are off a dsg car but mine s manual.
I'm in Manchester so I need to know if anyone can scan my car or check if they can fit.
Email shannykahn at yah*oo dot com
Remove *
Black Golf GT TDI (2004 54)
Edition 30 Front Bumper, Rear Bumper, Exhaust and Rear Lights.
GTI MFSW, R32 Highline Cluster and Gear Knob
Xenon Lights, GT Sport Alloys.
Offline Shanny
« Reply #66 on: August 07, 2013, 03:31:38 am »
jabberwokki
« Reply #67 on: October 19, 2016, 01:02:44 am »
Hi all, hope somebody can help have a 2004 mk5 golf 1.6fsi and after fitting a rns510 wanted to upgrade to a highline cluster i have vcds and vag commander 4.5 have managed to retreive the SKC from the old cluster and save a copy of the immo data using vag commander but new cluster i am struggling to read and write to cluster is a 1K0920974A after reading lots of threads on various site understand this is because original is immo4 and replacement is immo4c ...but also understand they can still be swapped can somebody point me in the right direction to either do myself or somebody in S.wales with the correct tool
many thanks
Offline dave1814
« Reply #68 on: February 09, 2017, 01:13:05 pm »
Sorry to revive this thread - but i assume if you have any problems with the new cluster you can always put the old one back in and the car will start?
thanks!
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #69 on: February 09, 2017, 01:18:41 pm »
thanks!
Yes it will.
Text me, i emailed you my number. I can answer all your queries regarding clusters
Offline mkmg76
« Reply #70 on: February 12, 2017, 05:56:27 pm »
Used this excellent guide this weekend to fit and code a set of highlines into my car.  :jumping:
Thank you OP. It was a great help.  :happy2:
« Last Edit: February 12, 2017, 05:59:31 pm by mkmg76 »
Offline dave1814
« Reply #71 on: February 12, 2017, 07:08:02 pm »
Can anyone recommend a VAG commander on ebay which would work with a 2005 GTI?
Thanks!
Offline dave1814
« Reply #72 on: May 10, 2017, 02:59:19 pm »
Hi guys, ive purchased a VAG commander cable which came with v1.4.
However, I can't seem to see the 'Read/write IMMO data' option - have i missed a step?
thanks,
Dave
Offline dronners
« Reply #73 on: May 10, 2017, 03:45:31 pm »
thanks,
Dave
what years your car ?  sounds like you have a newer year that cant be read. think its only up to early 2006 probably says in this thread somewhere
Offline dave1814
« Reply #74 on: May 10, 2017, 04:02:59 pm »
just sorted it - v1.4 didnt have the option, v3.6 didnt work but v2.5 seemed to do the trick!
