Author Topic: EGR blank on TDI  (Read 30569 times)
Offline vRS_Pagey
  • -Receive: 59
Re: EGR blank on TDI
« Reply #30 on: September 08, 2011, 09:34:33 pm »
Not sure about the CAT delete map but was told it was needed or the emissions light would pop up.
CAT delete maps aren't needed. I fitted a De-Cat to my pd140 earlier this year and it ran fine and no lights or vcds error codes, I've since had a Stage1 map loaded and thats fine with the De-Cat too.  :happy2:
Ahh, another Briskodian invader.  Thanks for your input buddy.   :happy2:
Offline four!
« Reply #31 on: September 08, 2011, 09:40:24 pm »
These people offer a couple of egr delete kits and it also says they have the ability to switch off the control unit.
http://fr-rtuning-shop.co.uk/AUDI/A3/A3-2003-2008/VAG-2-0-TDI-EGR-Roadsport-Delete-kit/prod_1706.htm
And there are some interesting tuning packages for the pd 140 listed too  :wink:
« Last Edit: September 08, 2011, 09:50:48 pm by four! »
Offline matt@theforce
« Reply #32 on: September 08, 2011, 09:54:40 pm »
NP.. Will be ordering a Darkside EGR when payday comes around & I have you and Wardy to thank for it   :P  Just need to speak to Ben next week when the car's in for a Service for getting the EML mapped out  :happy2:
Matthew
Offline will130787
« Reply #33 on: September 08, 2011, 10:44:27 pm »
That site is good, spent a good few minutes on there! Shame their miles away because theory maps look good and pretty cheap too....
Offline gr1zzle
« Reply #34 on: September 24, 2011, 11:56:33 am »
Hi lads another gt tdi driver do you recommend having this done on the gt 170 it's being remapped and dpf removal, do you think I should get the egr valve deleted ? Get conflicting info ?
Offline vRS_Pagey
  • -Receive: 59
« Reply #35 on: September 24, 2011, 04:28:54 pm »
I can't speak for the 170, but it has made a difference on my 140, I expect it's a combination of the map as well, but on my 10 mile run to work I was averaging between 42.5 - 47.5 mpg, on Monday I got 52mpg!!  :surprised:  That's a combination on 3-5 minutes on the motorway, and then twisty A roads.
The thing to look at is the EGR, is an efficient bit of kit up to about 30k (normal driving, servicing etc) after that it gets clogged which reduces performance and mpg.  You could whip it off, clean and refit, but if you are going down the route of DPF delete and remap you may as well invest the 70 sheets and get the EGR bypass also.
Something to bare in mind, removing it will increase emissions but they will still be way below the require for UK law.
I was looking at FR tuning, but was put off by reports of shocking customer service and wrong parts supplied, perhaps just an isolated incident, but the boys at Darkside are the nutts.  :happy2:
Offline Stevenebm
« Reply #36 on: September 24, 2011, 05:15:05 pm »
Think il order one of these before it goes for it's revo remap.think I'd be aswell getting full exhaust system fitted at the same time.
Offline vRS_Pagey
  • -Receive: 59
« Reply #37 on: September 24, 2011, 06:09:46 pm »
Be rude not too. :party:
« Reply #38 on: September 24, 2011, 06:34:26 pm »
been looking at doing this myself and getting a dark side egr delete,keeping looking at thier turbos as well :rolleye:
Offline vRS_Pagey
  • -Receive: 59
« Reply #39 on: September 24, 2011, 06:43:41 pm »
That's where I'll be going if my turbo goes.........
« Reply #40 on: September 24, 2011, 07:20:06 pm »
don't think its a IF for me,it will be a when ,the luck i have with turbos :signLOL:
Offline Scousus maximus
« Reply #41 on: September 24, 2011, 07:36:36 pm »
Chin up Andy!
Regards,
John
« Reply #42 on: September 24, 2011, 07:56:24 pm »
Chin up Andy!
Regards,
John
for got what my car looks like John :signLOL:
Offline Stevenebm
« Reply #43 on: September 24, 2011, 08:02:33 pm »
There is two kits on the website.roadsport and motorsport one.I take it it's the roadsport one I'd need before I order?
Offline vRS_Pagey
  • -Receive: 59
« Reply #44 on: September 25, 2011, 11:41:52 am »
If you are you talking about the FR one, then yes, you need the Roadsport one?  If you email Darkside Developments and ask for the delete kit for the 2.0 BKD engine, it's £70 posted from them, and customer service is second to none, they practically talked me through the DIY installation of mine. :happy2:
« Last Edit: September 25, 2011, 11:44:36 am by vRS_Pagey »
