Author Topic: Dazza's Maintenance Thread  (Read 110480 times)
Offline dnr1g
Re: Dazza's Maintenance Thread
« Reply #180 on: June 26, 2015, 01:50:17 am »
Looking good, Dazza! Greetings from another Tornado Red GTI owner in the Barcelona area.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #181 on: June 26, 2015, 03:14:14 pm »
Thanks mate about time we got another local member, I tried a Spanish forum but its dead.
05 | Tornado Red | DSG
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #182 on: July 05, 2015, 02:15:22 pm »
Went to a local GTI meet today. Less than 10 cars there but it was nice to see some fellow GTI enthusiasts.
I was surprised all the cars were pretty stock apart from the odd remap.
Things were ok until the Cupra 280 stole my thunder.   :drool:
Offline Pesky jones
« Reply #183 on: July 09, 2015, 11:41:18 pm »
Car looks very nice. How do you get the bumpers and Side skirts looking so nice?! Mine are a horrible dull grey
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #184 on: July 09, 2015, 11:48:00 pm »
Thanks mate!
I use Dodo Juice Supernatural Tyre Dressing.
Maybe the detailing gurus can recommend something even better.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #185 on: July 10, 2015, 10:46:38 am »
Started back on the boot build yesterday.
Wired up the thermostat sensor have no idea what temp to switch the fans on and off? Not seen the temp go above 30ยบ yet.
Contacted a company in the UK to see if they can cut the perspex for me as i was not happy with the circle edge when i did it my self.
The leatherette has all come unstuck any thought on a better material/glue to use?
I dread the day i get a flat the false floor is a perfect fit so i cannot get it out unless i lower the rear seats slightly easier said than done when the kids isofix seats are in the car.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #186 on: July 14, 2015, 09:06:18 pm »
Fitted a new (second hand) HPFP today.
Also some led interior lights from bold sport the kit arrived within a week. Only problem there is one bulb missing i think some mk5's only have two bulbs in the front?
Did a log just to check all is ok.
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #187 on: July 14, 2015, 09:16:58 pm »
Yeah, newer mk5's only have 2 bulbs (both my Golfs).
Your engine is now running well. :happy2:
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #188 on: July 14, 2015, 09:38:14 pm »
Seems to be running nice now thanks mate.
I will order another bulb.
I also need a bulb holder for one of the map lights. If anyone knows the part number.
Also noticed glove box light not working so will have to remove the glove box and check the switch.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #189 on: July 14, 2015, 09:55:21 pm »
Is this hole behind the glove box supposed to have the switch for the glovebox light??  :sad1:
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #190 on: July 15, 2015, 01:32:42 pm »
Led door warning lights are in. Simple once i found out what pins to use.
Pin 1 Positive. Sliced ground on to pin 4. No slicing needed on the passenger side again used pins 1 and 4.
Mattwoodison
« Reply #191 on: July 15, 2015, 08:36:04 pm »
Where did you feed the wire from the battery to the amp thru the engine bay? I've done them before but can't find an easy way thru...?
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #192 on: July 16, 2015, 08:23:26 am »
I have DSG so there is a hole where the clutch would be.
Offline doylebros
« Reply #193 on: July 16, 2015, 06:58:01 pm »
Does this help for the bulb holder Dazza http://www.partscats.info/volkswagen/en/?i=cat_vag_models&brand=vw&number=1714&set=1728&ein=2007&f=474&hauptgr=1234567890&hg=9&grf=094700420&bf=94705&hgug=947&ug=47&parent_id=2363557
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
