Author Topic: 5w 40 fully synthetic oil..  (Read 8798 times)
Offline jimmy-s3
« on: January 04, 2015, 10:16:24 pm »
Would there be any reason why you couldn't use 5w40 fully synthetic oil in an Edition30?
Re: 5w 40 fully synthetic oil..
« Reply #1 on: January 04, 2015, 10:19:27 pm »
A lot of people including myself move to 5W40 fully synthetic oil once running higher power levels. No reason not to use it.
Offline th3_f15t
  • -Receive: 183
« Reply #2 on: January 04, 2015, 10:22:59 pm »
Full synthetic will withstand higher operating temperatures in the engine itself for longer, and opting for 5w-40 over 5w-30 further aids this. I've also made the switch to 5w-40 fully synthetic oil.
Offline jimmy-s3
« Reply #3 on: January 04, 2015, 10:59:08 pm »
Sounds good to me!
Cheers.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #4 on: January 04, 2015, 10:59:21 pm »
I've always used 5w40 full syn.
Offline howie1987
  • -Given: 92
  • -Receive: 21
« Reply #5 on: January 04, 2015, 11:11:18 pm »
I've always used 5w 40 aswell. Last longer aswell.
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #6 on: January 04, 2015, 11:30:29 pm »
VW 504/507 approved oil is one grade only, 5w30.
5w40 is thicker at temperature, by how much I have no idea.
Make up your own mind.
'07 Red manual
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #7 on: January 05, 2015, 07:36:03 am »
Depends on the oil, if you look at the datasheets they give the viscosity at a given temperature. Quantum 5w40 is only marginally thicker than Castrol 5w30 at 100 degrees from memory
« Last Edit: January 05, 2015, 10:31:49 am by Dan_FR »
Offline xjay1337
  • -Receive: 377
« Reply #8 on: January 05, 2015, 09:55:30 am »
i use millers nanodrive 5w40.
not approved to any vw specs but the oil is much better...  :P
Offline th3_f15t
  • -Receive: 183
« Reply #9 on: January 05, 2015, 10:49:24 am »
I was lead to believe that although 5w-40 isn't VW spec, when running any level of tune the excess heat generated in the engine is controlled by the thicker oil. Certainly my engine feels smoother when running it through the upper rev range at temperature.
« Reply #10 on: January 05, 2015, 12:14:25 pm »
This....
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #11 on: January 05, 2015, 06:56:48 pm »
5w40 is spec for ours here in the states.
dansmith180
« Reply #12 on: January 05, 2015, 07:31:29 pm »
@ROH ECHT might be for the warmer climate?
What @MC71 posted is the stuff you need.
Offline dan930
  • -Receive: 56
« Reply #13 on: January 05, 2015, 07:48:00 pm »
What about 5w30?
MK6 golfR dsg
AKS TUNED
NORTECH PERFORMANCE HTA3071
R TECH custom map
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #14 on: January 05, 2015, 09:05:43 pm »
Quote
I'm good...thanks  :happy2:
Some here use 0w40 or even 0w30 in the colder states...but most here use 0w40 or 5w40.
If it is VW 502.00 and 505.00 coded.
« Last Edit: January 05, 2015, 09:09:41 pm by ROH ECHT »
