Author Topic: What is this broken. NSF  (Read 4856 times)
Offline Hannakournikova
« on: June 22, 2016, 02:32:11 pm »
Happened to see this today while having a nosey round.
Re: What is this broken. NSF
« Reply #1 on: June 22, 2016, 02:40:21 pm »
Xenon level sensor
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #2 on: June 22, 2016, 02:55:25 pm »
As above!
You can't replace the plastic, you need an entire new sensor unit. Very pricey piece of kit too.
Chances are your lights have been blinding people or pointing at the ground since it happened.
Cheapest fix is to cable tie it at the halfway point.
« Reply #3 on: June 22, 2016, 03:07:00 pm »
Silly question. But how should it look??
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #4 on: June 22, 2016, 03:13:39 pm »
http://www.golfmkv.com/forums/showthread.php?t=154324
Scroll down a bit.
It's connected to the wishbone. As you hit a bump, the wishbone naturally moves up/down with the pressure. This is reflected with the sensor and the headlight level changes accordingly.
Offline flashp
  • -Receive: 65
« Reply #5 on: June 22, 2016, 10:54:12 pm »
Not related to op's original  question but do these work as intended? You're driving along and you go over a bump or pothole, the wishbone moves, the suspension does its job and the car stays level....but your headlights move. Really? I can't see the sense in this. If it's set up to accommodate low frequency changes like load in the car by suspension compression then yes but not high frequency bumps surely?
Gone but not forgotten :-)
« Reply #6 on: June 22, 2016, 11:06:36 pm »
Its more to adjust the level if you have a heavy weight in the back or are towing which changes the pitch of the car
Offline TAPPY
  • -Receive: 56
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,103290.0.html
« Reply #7 on: June 22, 2016, 11:16:33 pm »
Pn should be  1K0941274B and the RRP is £114.47
« Last Edit: June 22, 2016, 11:43:53 pm by TAPPY »
Offline Pesky jones
« Reply #8 on: June 22, 2016, 11:24:53 pm »
The second point about low frequency changes makes more sense to me, which is backed up by what rich said
Offline ady-uk
  • -Given: 19
  • -Receive: 24
VW Golf 2.0 Gtd 140 4motion (2005)
Factory fitted: xenons, sunroof, heated leather seats, fold in mirrors with downlights,
Custom: Mk6 steering wheel, updated gateway, RNS510 remote boot pop, LED lighting.
Offline Juliand
« Reply #10 on: June 23, 2016, 11:45:56 am »
Good link that last post.....Now I see what it's all about. What a complex set up, just to level headlights! What's wrong with just being able to do it manually with a twirly thing next to the headlight switch for up or down. As commented, really only for heavy weight in the back of the car, otherwise the lights would be up and down like a yo-yo - over-engineered - in my opinion. Something else to look out for.......where's my torch? :doh:
