Author Topic: What did you and your MKV do today?  (Read 4048736 times)
Offline Sebas_theFish
« Reply #12180 on: July 30, 2021, 11:43:16 am »
New wiper linkage and new steering wheel.
Sent from my Samsung Smart Fridge
Ohhhhhh just spotted your ‘Joying’? stereo?
Tell us all about it... Do you rate them? CarPlay work ok? Any battery drain issues? Etc
Cheers  :happy2:
It works well, no battery drain issues. Don't need Carplay on it as it runs full Android. Works with steering wheel controls, downloaded my Spotify playlists on it so I can listen offline but have a dedicated hotspot in the car for Waze.
Offline Rampage
« Reply #12181 on: July 30, 2021, 11:50:44 pm »
Thanks for the info... looks and sounds like a good ‘modern’ option for the mk5. Cheers  :happy2:
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #12182 on: July 31, 2021, 02:03:15 am »
That's good going and highly unusual!  Normally expect to see -3 or -2 at idle when cold/warming up, but after a drive that can move to -1 or 0 as the VVT moves things around.  Once the chain wears to the point of the tensioner running out of travel, that's when things can drift to -5KW or more.  But that's only 5 degrees, which isn't even a tooth off.....so I don't think things will ever get so bad it runs like crap......unless the chain snaps!
So...I did say those angles were spec, but there truly is no spec that I know of for the EA113. Those angles is just what is said, apparently by some VW/Audi techs, for the TSI EA888. So, I have recently been attempting to find out if the same goes for the EA113...in that; 0 to 3°kW=good__4°kW=may result in noise etc..__5°kW=be prepared to change the chain and tensioner asap. But I have not received any confirmation if these numbers also apply to the EA113. Have you heard they are?
Offline Octoparrot
  • -Receive: 104
« Reply #12183 on: July 31, 2021, 07:26:22 pm »
Car clocked 155,000 miles today.
Offline DBXdarkangel
  • -Given: 18
« Reply #12184 on: July 31, 2021, 09:45:34 pm »
My indicators stopped flashing when locking the car. Checked every door activated the interior light and all OK.
Ran vcds and turns out my passenger rear Dock lock has packed in. Can hear it clicking but it's not locking the door. Had to pull off the door handle black end that connects to the silver wire in order to stop someone opening that door and breaking in.
Ordered new door lock to fit next week.
Offline fakie1977
« Reply #12185 on: August 01, 2021, 11:55:00 am »
Finally got around to fitting new genuine charcoal canister and pipe. That should clear my last fault code and help car run better.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #12186 on: August 01, 2021, 10:34:22 pm »
Received my new NGK BKR7EIX plugs....NGK site has them shown to come with a 0.8mm gap, mine came 0.7mm gap. With new APR coils on the way, a 0.8mm is my preference so I opened them. I first double checked the gap gauge with the caliper and my 0.7mm gauge is 0.69mm. The 7.5mm gauge is 7.3mm. My gauge set comes; 0.6mm__0.7mm__0.75mm__0.9mm__1.0mm...and doesn't have a 0.8mm for whatever reason. So I filed down the 1.0mm gauge wire on one side to 0.8mm. Man, I need something else to do with my life!
« Last Edit: August 02, 2021, 02:44:41 am by ROH ECHT »
« Reply #12187 on: August 01, 2021, 10:51:53 pm »
I’ve never checked the gap on my plugs. Maybe I will the next time I change them.
  • -Given: 18
« Reply #12188 on: August 04, 2021, 07:01:20 pm »
Got as far as removing the door skin to replace the door mechanism. Only to find there was 3 suction cups in the door well and someone has butchered the m6 screws holding the lock on!. Luckly a pair of locking mole grips got them undone so now waiting until the weekend for the replacement m6 spline screws to arrive before I carry on.
Offline Lewo
« Reply #12189 on: August 04, 2021, 10:16:59 pm »
Yes they're tripple squares or something aren't they, I'd never heard of them before having to change the door module so that shows how much I know about spannering lol.
  • -Given: 18
« Reply #12190 on: August 04, 2021, 11:19:00 pm »
Yeah there WHT000439 splines. Might call the stealers tmr to see how much they are from them so I can do the job sooner than waiting for the replacement ones to turn up monday
« Last Edit: August 05, 2021, 02:00:42 pm by DBXdarkangel »
Offline Stupots
  • -Given: 18
« Reply #12191 on: August 05, 2021, 10:47:42 am »
A correctly sized Hex/Allen key also works in most cases, but not now they’ve been rounded off.
2006 VW Golf Mk5 Sport TDI 4Motion (140 BKD)
  • -Given: 18
« Reply #12192 on: August 05, 2021, 02:02:32 pm »
Joys of a car having previous owners I guess. Once the replacements arrive I can crack on and get it done. Easy job when you've done one side. Just looks scary bit it's not  :happy2:
Offline colesey
  • -Receive: 89
« Reply #12193 on: August 06, 2021, 11:35:42 am »
Updated the light switch to a newer style one. Should also replace the window switches as the rubber of the originals has become worn.
  • -Given: 18
« Reply #12194 on: August 08, 2021, 12:18:26 pm »
Fitted new rear door locking mechanism. All working as it should now. Indicators flash when I hit lock button.
Vw charged me £267 labour. Was a 45min job so not sure what they was doing that too 2.5hrs.. also they charged me £121 for a part that cost me £23.
Total cos from them was £443..  total cost for me to do including new bolts, door lock and a socket was £40
