Author Topic: What did you and your MKV do today?  (Read 4006467 times)
Offline andyp
« Reply #5655 on: January 26, 2014, 09:31:12 pm »
That looks factory tbh,  it wouldn't mark easily though would it?
Offline GarethB
« Reply #5656 on: January 26, 2014, 09:38:34 pm »
Finger prints - yes, but are easily wiped clean
Minor surface scratches are easily polished out  :happy2:
It's no easier to damage than the standard plastic finish
Thinking about it, the finish that he uses is used on exteriors, so I think it's fairly tough - I was seriously contemplating getting the R32 lower rear bumper insert hydro dipped as i reckon he could achieve a finish darn near osir's proper carbon insert.
Liam0205
« Reply #5657 on: January 26, 2014, 09:49:59 pm »
^^^^ That will look awesome. I paid £80 for the 2 dash trim pieces. Am sending off a load more pieces to be done now!  :pomppomp:
For those that've asked. Here's a pic of mine. Needs rebuilding and fitting but looks the nuts IMO.......
Nice
Was thinking out getting the plastic surrounding my DSG gear stick done as mine has a scratch which is bugging me and have found a place locally that does it.
Offline GarethB
« Reply #5658 on: January 26, 2014, 09:59:13 pm »
Nice
If it's a deep scratch, you may want to consider buying a new piece of trim from TPS, and send him that for dipping. It's only a very thin layer that is added, so imperfections in the moulding or damage will not necessarily be covered up by this process.
Don't forget the mention the forum if you contact him.
If you're local to Maidstone and want to see his work, I'm happy to meet up to show you the interior pieces he did for me  :happy2:
« Reply #5659 on: January 26, 2014, 10:06:05 pm »
Looks awesome  :happy2:
I'm glad that you've had some parts done by Adrian. The guy's work is excellent, and with you being a 'fairly'  :laugh: active poster on here, I could see him getting some more business from the forum.
IIRC he did my stereo surround, top vent surround, ash tray surround, gear gaitor surround (all shown in my pic), passenger & driver side vents and drivers side door handle for about £120. I need to get my passenger handle (and head light switch surround - if I can ever remove the bugger) to him to complete the interior  :happy2:
I'd happily recommend his work to anyone, and I'm sure that Adrian would sort a discount for forum members.
I'll be sending off the other interior parts to be done after receiving those bits back. I wondered about that headlight switch surround too.
Will happily recommending him too, great work, quick turn around a reasonable price.
Liam0205
« Reply #5660 on: January 26, 2014, 10:07:52 pm »
Nice
Thanks man, in Milton Keynes so not very local  :grin:
I just assumed they would strip the existing coating and then dip it after rather than just cover the existing material???
Offline GarethB
« Reply #5661 on: January 26, 2014, 10:15:11 pm »
Mine seems to be plastic welded to the lower section of the dash, and not easily removable at all. I'm sure I read that on some mk5s, you remove the highlight switch and the T25 screw behind it and the surround come out. Mine is deffo not that simple  :sad1:
Offline GarethB
« Reply #5662 on: January 26, 2014, 10:21:39 pm »
Sadly I don't actually know the process used. I know that it is very thin layer tho as there is very small crease-like line in the moulding of the driver side arm rest, which became apparent due to the high gloss finish. It is very tricky to see though.
Offline Rob.
« Reply #5663 on: January 27, 2014, 11:19:32 am »
I finally got round to changing my cam follower, as well as swapping my DV from a Rev C (looked fine) to a Rev D  :happy2:
I posted a bit of a guide, in case anyone else had to tackle a fuel pump with a banjo bolt
http://www.mk5golfgti.co.uk/forum/index.php/topic,78451.msg818537.html#msg818537
Next job is to take out my front seats and see if bypassing the yellow connectors underneath will get rid of my airbag warning light  :chicken:
Offline Gra
« Reply #5664 on: January 28, 2014, 02:48:58 pm »
Spotted my gbox mount was shagged so booked in for warranty job just before warranty runs out saves me the hassel of changing it.
Offline skriller
« Reply #5665 on: January 28, 2014, 08:26:39 pm »
almost flipped my car trying to pull off the motorway to get this shot.... :confused:
Mileage  :happy2: im mad about the numbers like this  :laugh:
DSG No.0106 T Red
Offline craigy123
  • -Receive: 24
« Reply #5666 on: January 28, 2014, 10:53:57 pm »
Sold my 2008 candy white revo stage 2+ edition 30. Man I'm gutted!!  :sick: :sad1:
PM for details
Offline trs888
  • -Given: 17
  • -Receive: 20
« Reply #5667 on: January 29, 2014, 01:04:21 am »
Did this:
https://www.youtube.com/watch?v=8dTj33BGDTk
Just in preliminary stage. Hope to get a final version within the next week.
« Last Edit: January 29, 2014, 12:39:23 pm by trs888 »
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #5668 on: January 29, 2014, 07:01:30 am »
^^^ what is it? Its not loading for me for some reason!
Offline trs888
  • -Given: 17
  • -Receive: 20
« Reply #5669 on: January 29, 2014, 12:39:42 pm »
post updated. works for me. and on my phone!
