Author Topic: EGR blank on TDI  (Read 31197 times)
Offline mortygttdi
  • -Receive: 146
EGR blank on TDI
« on: September 05, 2011, 11:25:09 pm »
Hi guys ive fab'ed a temp EGR blank at work and stuck in place of the gasket between the EGR valve and the smaller take off pipe to the side of it...the one that goes round to the back of the engine.
On testing it there is no lights on the dash and it runs nice and smooth? But is there other things I need to have done or am I in the right place???
Darren
Re: EGR blank on TDI
« Reply #1 on: September 06, 2011, 09:37:59 am »
thing you have to blank of both ends of the pipe which you mention Daz :happy2:
Offline mortygttdi
  • -Receive: 146
« Reply #2 on: September 06, 2011, 01:52:52 pm »
Done that Andy just put a blanking plate between the gasket and bolted back on
Darren :happy2:
Offline vRS_Pagey
  • -Receive: 59
« Reply #3 on: September 06, 2011, 05:00:59 pm »
I have a Darkside Developements EGR delete pipe in place and for the first 20-30 miles no CEL, then it came on.  I switched it off with my Shark STS, but it reared its ugly head a few miles later.  It has now been permanently removed on my stage 1 software.
If and when the CEL does come on, you can either leave it (not going to do any harm) or have your standard/remap modified to flash it out.
Offline mortygttdi
  • -Receive: 146
« Reply #4 on: September 06, 2011, 08:53:54 pm »
Cheers Pagey, last night I took the small vac pipe off and plugged it, left the other side open and it took around 80 miles for the CEL to come on, I turned it off with VCDS so just waiting for it to come back on...but will get S/C to send me a modded map with the EGR delete.
Cheers again
Darren :happy2:
Offline Johnny_tro
« Reply #5 on: September 06, 2011, 09:03:17 pm »
Hope you don't mind me asking :ashamed: whats the benifits to blocking/blanking this off?
'VANDALISED' MK5 GT :( - RNS510 H, Bluetooth Armrest, MDI, 50gb hard drive, I can't park  sensors, Cruise Control, Highline Display, MFSW, Heated Seats, Remote Aux Heating System (Heats and Vents) Winter Pack, Heated & Folding Mirrors, Puddle Lights, Xenons, Headlamp Washers, Heated Washers, Auto lights and wipers, LED's, GTI brakes,, black R32 roof lining, Scirocco Rear View, Rear Footwell Lights
Offline mortygttdi
  • -Receive: 146
« Reply #6 on: September 06, 2011, 09:13:13 pm »
I believe it stops parts of the engine from building up with crud if you blank it off???? Someone with better knowledge of the system will be along shortly.
Darren
Offline vRS_Pagey
  • -Receive: 59
« Reply #7 on: September 07, 2011, 10:10:04 am »
Darren's explanation is spot on really, over time crud will build up in the EGR valve reducing the diameter and with it air flow.  You don't necessarily have to fit a delete pipe, if you have the time, you can remove the EGR and leave it to soak overnight in either carb cleaner or similar.  Once clean simply refit.  However the advantage to going for a bypass is the internal diameter of the delete pipe is greater and also there are no internal obstructions.
The pictures below should illusrate this.
My OE EGR valve -
Delete pipe -
Fitted -
Mine had covered a little over 45k, and tbh wasn't that bad, the last picture is from a vehicle which had covered less miles.  Poor servicing, fuelling and enviroment can all play a part in how bad they can get.  Imo, for 70 quid it's a no brainer, as I noticed increase throttle response and over a couple of runs the mpg increased slightly.
HTH, Lee.  :happy2:
Offline 81lly
« Reply #8 on: September 07, 2011, 04:12:03 pm »
Should the egr valve be cleaned every 40k odd miles?
Offline vRS_Pagey
  • -Receive: 59
« Reply #9 on: September 07, 2011, 04:28:31 pm »
I can't see any harm in it.  Now I have done it once I reckon I could remove/refit in 20 minutes, there is one bolt at the rear that is awkward to get to but once I figured I could use an allen key it wasn't a big deal.
Offline 81lly
« Reply #10 on: September 07, 2011, 04:46:21 pm »
Would the delete pipe be an better option to cleaning the egr valve?
Offline mortygttdi
  • -Receive: 146
« Reply #11 on: September 07, 2011, 05:19:42 pm »
Yes IMO it would, and I will be doing what Mr Pagey has done in the near future but just has a temp measure I have made my own delete plate and disconnected the vac pipe,
Big thing for me at the moment is I got an email back from S/C and they said they do not support the EGR delete on there files.
Good afternoon.
I am glad to hear that the car is now running well. Unfortunately EGR removal and deactivation is not something we support or offer with our files.
Kind Regards
Michael Howard.
So will be thinking defo going to see Dave @ PDT once the Darkside delete is in place.
Darren
Offline vRS_Pagey
  • -Receive: 59
« Reply #12 on: September 07, 2011, 05:27:49 pm »
They're tuners but they can't map out an EGR delete???  :surprised:
Offline 81lly
« Reply #13 on: September 07, 2011, 06:56:42 pm »
I will get mine ordered soon.. I can drive around for a few months with out a ecu map and it won't go into limp mode?
Offline vRS_Pagey
  • -Receive: 59
« Reply #14 on: September 07, 2011, 07:08:14 pm »
I was assured by Darkside that an EGR delete was extremely unlikely to cause limp mode.
