Author Topic: Brake upgrade  (Read 16935 times)
Offline vRS_Pagey
  • -Receive: 59
Re: Brake upgrade
« Reply #15 on: January 27, 2012, 07:02:14 pm »
To save me jacking up the car and removing a wheel, can anyone confirm the type of bolt holding the carrier to the hub?  Is it a large torx bit or a standard nut?
Offline dodds-gttdi
  • -Given: 22
  • Edinburgh
Re: Brake upgrade
« Reply #16 on: January 27, 2012, 08:34:16 pm »
M12 spline I was once told. Can't, for the life of me, totally remember. Hopefully somebody will be along to confirm/correct. :happy2:
Re: Brake upgrade
« Reply #17 on: January 27, 2012, 08:38:19 pm »
Its just a bolt mate. 18mm i think!
Offline the bruce
  • -Given: 322
  • -Receive: 101
    • my GTI
Re: Brake upgrade
« Reply #18 on: January 27, 2012, 09:58:00 pm »
Another option is to sell the 288mm set to someone who need the lightest brake set for their 1/4 mile car (like I did) or if someone's caliper needs replacing due to fatigue.
 :happy2: :drinking: :happy2:
@ all:
If you are in doubt which strut diameter you have watch the caliper:
- if there's a ''FSIII'' on the caliper face > 50 mm
- if there's a ''Ate'' logo on the front edge > 55 mm
"You get what you pay for."
Offline vRS_Pagey
  • -Receive: 59
Re: Brake upgrade
« Reply #19 on: January 28, 2012, 01:37:48 pm »
Yup, definitely a bolt, just turned the wheel and took a couple of pictures, cheers, mate.  :happy2:
Offline the bruce
  • -Given: 322
  • -Receive: 101
    • my GTI
Re: Brake upgrade
« Reply #20 on: January 28, 2012, 02:28:38 pm »
If you loosen (and tighten) the caliper carrier jack the car VERY safely up !!!
From what I remember the required torque is 180 Nm, even more than the wheel bolts !!
Hold the (torque) wrench horizontally and put force vertically only (strictly recommended
in VW's ELSA repair guide).
Offline vRS_Pagey
  • -Receive: 59
Re: Brake upgrade
« Reply #21 on: January 28, 2012, 03:09:28 pm »
Good advice mate, I can imagine the consequence's of tightening a bolt with that type of force with the car not secure on axle stands........
Is it definitely 180nm, that's over 130lb/ft?  :scared:
Offline the bruce
  • -Given: 322
  • -Receive: 101
    • my GTI
Re: Brake upgrade
« Reply #22 on: January 28, 2012, 03:33:29 pm »
Yes, I'm pretty shure as I did this a few weeks ago when I changed my discs.
 :wink:
Re: Brake upgrade
« Reply #23 on: January 28, 2012, 03:49:25 pm »
The fronts are easy to change over but the rears are a bit awkward to get into the spline bolt
Offline vRS_Pagey
  • -Receive: 59
Re: Brake upgrade
« Reply #24 on: January 28, 2012, 05:41:53 pm »
I will leave the rears to my mechanic, but I will be changing the fronts myself if I can get a suitable torque wrench from work.
Re: Brake upgrade
« Reply #25 on: January 28, 2012, 10:24:45 pm »
f/t tight is normally good :signLOL:
Offline vRS_Pagey
  • -Receive: 59
Re: Brake upgrade
« Reply #26 on: January 29, 2012, 06:04:39 pm »
They ain't Scania wheel nuts....... :grin:
Offline the bruce
  • -Given: 322
  • -Receive: 101
    • my GTI
Re: Brake upgrade
« Reply #27 on: January 29, 2012, 06:45:33 pm »
I wouldn't take any risk on brakes.  :wink:
Too tight - thread of caliper carrier damaged.
Too loose - I don't really want to think about that . . .
Re: Brake upgrade
« Reply #28 on: January 29, 2012, 11:41:11 pm »
Its 190NM according to the guide ive got. Same ballpark though.
Offline vRS_Pagey
  • -Receive: 59
Re: Brake upgrade
« Reply #29 on: January 30, 2012, 04:20:47 pm »
 :scared:
