Author Topic: LED Rear Light 'Polo' Mod  (Read 6529 times)
Offline Kalpsn2000
  • -Receive: 56
« on: February 25, 2013, 11:13:56 am »
Hey guys
I remember reading about it a while ago but can't find the thread/article.
I'm looking for info to make the rear outer lights have a 'polo' effect when on, rather then the whole light being on. Basically want the centre circle to only come on when braking.
Can this be done via VCDS or do you need to get physical?
Not looking to do the 'skyline' mod, i.e. make the inner lights LED, right now.
Kalpesh
Offline Matto
  • -Receive: 116
Re: LED Rear Light 'Polo' Mod
« Reply #1 on: February 25, 2013, 01:00:28 pm »
I've had it where it only shows the inside half of the outer ring and the full ring when braking. Are you saying you want just the outer half of the outer ring on unless braking. Like this (...............)?
« Reply #2 on: February 25, 2013, 02:47:29 pm »
Like mine below Kalpesh?
It is only coding that's required, only the outer portion of the LED's are lit and then the whole unit lights up when the brake is applied. Does need the inner units doing now IMHO.
Sorry for the dodgy pic, the lights are red, honest.  :laugh:
« Last Edit: February 25, 2013, 02:49:00 pm by MC71 »
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #3 on: February 25, 2013, 03:03:55 pm »
I read up about this a few months back,
You have to solder a small wire on the bulb carrier. A few people who had pre 07 golfs had no problems but others had bulb out warning on the dash board.
I would like to know if there is a coding way for UK cars. I know on US models it can be done via coding.
Offline Kalpsn2000
  • -Receive: 56
« Reply #4 on: February 25, 2013, 03:09:17 pm »
Yes that's exactly what I'm looking for Martin :happy2:
How can I do that? What coding needs doing?
Offline Matto
  • -Receive: 116
« Reply #5 on: February 25, 2013, 04:20:41 pm »
It should be the full ring as standard. I sorted Richwig's out the other week. If you have access to VCDS send me your long coding for address 09 and I will take a look at it.  :happy2:
« Reply #6 on: February 25, 2013, 05:33:48 pm »
Not on the Valeo LED light clusters (which i and Kalpesh have) as the whole unit is lit when the park lights are on, to get the "Polo" look, it needs coding.
@ Kalpesh
I had mine coded by a chap who mainly frequents the R32OC site. Try Eddie or have a look through this thread from the golfmkv.com site......
~~ Clicky here ~~
Offline Matto
  • -Receive: 116
« Reply #7 on: February 25, 2013, 05:38:36 pm »
Ah ok. I thought this was for standard rear lights  :ashamed:
Offline chrisr763
  • -Receive: 62
« Reply #8 on: February 25, 2013, 05:46:23 pm »
So for the standard set of lights. How is this look acheived?  :ashamed:
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #9 on: February 25, 2013, 05:52:55 pm »
Its already like this on a standard car is it not? A full ring and then half a ring on braking?
Offline chrisr763
  • -Receive: 62
« Reply #10 on: February 25, 2013, 05:54:48 pm »
What I mean is the full ring on brakeing  :P
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #11 on: February 25, 2013, 05:58:28 pm »
You can tell its been a long day  :rolleye:
Offline Matto
  • -Receive: 116
« Reply #12 on: February 25, 2013, 06:00:58 pm »
I think this can be done but from memory meant soldering a jumper wire across the lamp holder. The problem with this is that it throws a bulb failure warning.
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #13 on: February 25, 2013, 06:01:51 pm »
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Re: LED Rear Light 'Polo' Mod
« Reply #14 on: February 25, 2013, 06:12:17 pm »
Thats the guide I was looking for
Cheers joe for posting that
Sent from my GT-I9300 using Tapatalk 2
