Author Topic: Boost gauge  (Read 5806 times)
Offline SurreyED30
Boost gauge
« on: November 27, 2013, 07:55:19 pm »
Good evening all
Not trying to 'spam' here at all, just want a simple answer that all before my head is bite off haha!
Ive searched threw a few threads on newsouth boost gauge fitting, however none that are explained/pictured very clearly for a 'amateur modder' like my self. I'm all for learning how to maintain and also mod my ed30 but of course you need to be shown things to learn. I have thread many breads in installing mods and some of you may have seen in the newbies section hat I've brought quite a few nods now that with the info on this forum I am more than 100% confident in fitting these my self.
All I'm after is where the t piece is fitted too, what connectors etc go where?
If some one has a 'baby's guide' on installing a newsouth I'd appreciate your time post here greatly  :happy2:
Or if you know of a very simple well pictured and explained guide
Feel free to help me if you live near Crawley/lingfield  :signLOL:
J
Offline SurreyED30
Re: Boost gauge
« Reply #1 on: November 27, 2013, 07:56:45 pm »
I have read many threads *  :signLOL: autocorrect at its best  :congrats:
Offline Alexis
Re: Boost gauge
« Reply #2 on: November 27, 2013, 08:21:51 pm »
I used the APR tap and that way you don't need to cut any existing pipes to fit the t-piece.  This just slots on and already has a ready made outlet that you connect your pipe to from the back of the boost gauge.
http://www.goapr.co.uk/products/boost_tap_20t.html
Re: Boost gauge
« Reply #3 on: November 27, 2013, 08:47:56 pm »
Use the thick hose they sent you, the one with the tap in it. Looks like this and attaches via the bottom of the breather hose of the PCV. looks like this......
Much as the APR one I use the Forge one which allows more than 1 tap due to my zorst powervalve hose. Also fits straight on. Pic with just one hose attached to it via the bottom tap...........
« Last Edit: November 27, 2013, 09:04:31 pm by MC71 »
Offline edd666999
  • -Receive: 89
Re: Boost gauge
« Reply #4 on: November 27, 2013, 08:56:13 pm »
I tried to find a good image of where the t piece goes, could only find those breather hose connections.
Offline SurreyED30
Re: Boost gauge
« Reply #5 on: November 27, 2013, 09:05:58 pm »
Use the thick hose they sent you, the one with the tap in it. Looks like this and attaches via the bottom of the brother hose of the PCV. looks like this......
Thanks man, always helpful every time  :happy2: I'll give it ago Sunday do doubt ill **** it up  :signLOL:
Thanks for your time to help man, appreciated.
All you 'long term' guys on here are mega helpful, forums from previous cars I've had have been a ball ache most of the time.
This site is awesome :happy2:
Offline Bow
Re: Boost gauge
« Reply #6 on: November 27, 2013, 09:46:55 pm »
I also need to know where t piece goes could you circle it on the picture somehow. I can't really make it out lol.
Offline edd666999
  • -Receive: 89
Re: Boost gauge
« Reply #7 on: November 27, 2013, 09:49:53 pm »
I'll post a picture tomorrow
Offline SurreyED30
Re: Boost gauge
« Reply #8 on: November 27, 2013, 09:50:16 pm »
Anyone want to fit my boost gauge for cash this week  :signLOL:
Bolt on mods, fine no problem what so ever could read something once and go crack it out but this is a recipe for disaster.
I've got 2 bags of assorted tubing clips connectors cableties bolts and a roles up length of additional tubing  :rolleye:. Thought it would be a piece of cake but leaning towards getting someone to fit it  :sad1:
Offline SurreyED30
Re: Boost gauge
« Reply #9 on: November 27, 2013, 09:51:37 pm »
Glad I'm not the only one ive been baffled all evening  :rolleye:
Offline edd666999
  • -Receive: 89
Re: Boost gauge
« Reply #10 on: November 27, 2013, 09:53:43 pm »
It's easy! I managed it so you will be able to. Hardest part is getting the tube into the cabin. Long screwdriver and duct tape
Offline SurreyED30
Re: Boost gauge
« Reply #11 on: November 27, 2013, 09:59:50 pm »
Okay cool, without sounding like a child, could you post a pic tomorrow of where the t piece goes and what tubing I run off it into the cab? Also what is all the additional tubing plastic t piece and clips for? I've got a brass square block with a outlet. Where does this go?
I thought, I'd connect the t piece, cable tie a hose to it, run the same hose into the cab then into the back of the boost gauge. Connect the red wire In to the grey illumination wire in the light loom then tie hhey black wire down behind a metal bolt, insert gauge into column pod, secure column job done.
Sorry to sound 'stupid' never fitted a gauge in my life  :signLOL:
Thanks for your patients
J
Offline edd666999
  • -Receive: 89
Re: Boost gauge
« Reply #12 on: November 27, 2013, 10:08:31 pm »
J
Sound like a plan. It might not be the "fitting a boost gauge plan" but it passes the time  :grin:
Post a picture up of what bits you got with the pod. I'll tell you what I did. Mine worked fine but I'm not saying I'm the all knowing boost gauge guru.
Offline SurreyED30
Re: Boost gauge
« Reply #13 on: November 27, 2013, 10:43:57 pm »
Here's all of the consumables that come with awesomegti's newsouth/column bundle  :happy2:
Hope you can rule out what is needed and what is not
Re: Boost gauge
« Reply #14 on: November 27, 2013, 11:22:24 pm »
^^^^ Brass bit attaches to the rear of the gauge. One of the 2 short silicone hoses attaches to that. Inside that fits the long/thin/main hose. Cable ties are to keep those bits together. Don't attract anything up until the long hose has been fed from the engine bay or the cabin though. The other short silicone hose attaches to the other end. I'd use the breather hose section, it has the tap in it to attach the silicone hose to.
Oh and the cocktail sticks are for little sausages and cheese/pineapple  IIRC.   :signLOL:
