Author Topic: Car alarm  (Read 5082 times)
Offline Chris92
  • -Given: 33
Car alarm
« on: January 07, 2014, 07:25:59 pm »
Hi
I've had my mk5 gti for around 6 month now and I've never heard the car alarm once so yesterday I locked it and tried to set it off by rocking it but that never worked so then I sat inside and locked it again and tried to set the alarm off again but it never went off. Are these car just stubborn to set the alarm ringing or do I have a problem? The red light flashes on the driver door when you lock it from the key fob. Any ideas?
Offline xjay1337
  • -Receive: 377
Re: Car alarm
« Reply #1 on: January 07, 2014, 07:38:04 pm »
Scan the car maybe there is a fault with the alarm system.
Presume it has one fitted..
Offline Chris92
  • -Given: 33
Re: Car alarm
« Reply #2 on: January 07, 2014, 07:49:06 pm »
I think I read that some of the imports didn't have alarms or something but surely it does or why have that red flashing light as I always throught they were to do with the alarms, but yes I think il get it scanned
Offline skard
  • -Receive: 245
Re: Car alarm
« Reply #3 on: January 07, 2014, 07:51:12 pm »
If just your indicators flash then most likely the battery in the siren has died/burst.
But could be loads of things...deactivated, faulty sensors or worse, it is an import
Offline skard
  • -Receive: 245
Re: Car alarm
« Reply #4 on: January 07, 2014, 07:52:33 pm »
Take your OSF arch liner off and look for an aluminium box, if you can't scan it
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
Re: Car alarm
« Reply #5 on: January 07, 2014, 07:56:31 pm »
Had a similar thing when I got my car... it turned out the Alarm Siren was dead, but better than that, it had been switched OFF in VCDS :confused:
The Siren is riveted on and can be got at through the offside wheel arch, I didn't bother having a go at it, as I thought it'd been through enough, lol, but it's an easy enough job once you've drilled it out, can grab them on eBay for ~£30. :happy2:
Offline Chris92
  • -Given: 33
Re: Car alarm
« Reply #6 on: January 07, 2014, 08:09:10 pm »
Thanks for the help, so if it is the siren box will that show up when I scan it? As long as it's not an import and it can be fixed I don't mind. Even if the siren was dead wouldn't the lights still flash if the alarm was/should be going off?
Offline xjay1337
  • -Receive: 377
Re: Car alarm
« Reply #7 on: January 07, 2014, 08:17:55 pm »
Nothing wrong with Imports.... !!!!
The red light will flash anyway on the door
You can verify you have an alarm by checking on the drivers side door pillar on the inside there will be 2 buttons for the alarm controls and on the passenger side between the front and rear doors on the roof there will be a sensor unit.
Offline skard
  • -Receive: 245
Re: Car alarm
« Reply #8 on: January 07, 2014, 08:24:03 pm »
^^If that was in reference to me, I was making no judgement of imports other than they do not come with an alarm so it is a big job to fit an OEM one
Offline doylebros
  • -Receive: 310
Re: Car alarm
« Reply #9 on: January 07, 2014, 08:27:17 pm »
Image of switch
http://www.ebay.co.uk/itm/VW-Skoda-SEAT-alarm-deactivation-button-6Q0962109-New-genuine-VW-part-/110876181427
Imports some come with alarms and some come with electric seats - anyone else got them on their MKV?
Offline xjay1337
  • -Receive: 377
Re: Car alarm
« Reply #10 on: January 07, 2014, 08:29:40 pm »
Alarm button on a Mk5 is this?
« Last Edit: January 07, 2014, 08:35:41 pm by xjay1337 »
Offline Chris92
  • -Given: 33
Re: Car alarm
« Reply #11 on: January 07, 2014, 08:34:38 pm »
Image of switch
That switch in the link I have that on my driver side b pillar, can't see anything on the passenger side tho
Offline xjay1337
  • -Receive: 377
Re: Car alarm
« Reply #12 on: January 07, 2014, 08:36:22 pm »
On the ROOF lining :)
Offline brough74
Re: Car alarm
« Reply #13 on: January 07, 2014, 08:36:38 pm »
Mine went off last night at about 2.30am i presume it was the very blustery wind and hailstones / sleet that must of rocked it and set it off.
I did check and no one was about and my security lights were all off.
Anybody had the same issue with strong winds ? or is it just a 1 off ?
PEARL DIAMOND BLACK 3dr GTI
HEATED LEATHER,MULTI FUNCTION WHEEL,
18” MONZA ALLOYS, XENON HEADLIGHTS, FLAT TYRE INDICATOR
LUX PACK AND WINTER PACK
SHARAN AERIAL, GTI TAX DISC HOLDER, R32 REAR LIGHTS
VW RACING FRONT SPOILER
Offline Chris92
  • -Given: 33
Re: Car alarm
« Reply #14 on: January 07, 2014, 08:56:58 pm »
I've just been outside to take some pics of what I have
This is on the driver side B pillar near the bottom
This is the passenger side one on the roof lining
They look different from what you posted Xjay
« Last Edit: January 07, 2014, 08:58:58 pm by Chris92 »
