Author Topic: Cold Air Feeds In Fog Grills  (Read 19323 times)
Re: Cold Air Feeds In Fog Grills
« Reply #15 on: August 17, 2014, 07:16:11 pm »
Cable tied to the screw holed that the fogs screwed into
Offline Tazgti5
« Reply #16 on: August 17, 2014, 07:18:50 pm »
Going off topic your bottom splitter looks good
« Reply #17 on: August 17, 2014, 07:20:22 pm »
Excuse the filthy car  :ashamed:
« Reply #18 on: August 17, 2014, 07:24:21 pm »
As Mike says, run ducting from grill to CAI and/or brakes.
Pic of mine fitted in the above post, removed pic and engine bay pic below. Remove fog light to fit as its too tight then after ducting put into place then refit fog light.
Offline Tazgti5
« Reply #19 on: August 17, 2014, 07:28:22 pm »
I really like this mod !! :congrats:
Offline Monkey10
« Reply #20 on: August 17, 2014, 07:36:20 pm »
Thank you for the link, are they a good fit?
Hi , I've just bought some open grilles off of eBay £19.80 delivered are a perfect fit and in my opinion look a lot better than standard ones. Jut got to get some ducting to my filter now.  :happy2:
Offline Tazgti5
« Reply #21 on: August 17, 2014, 07:41:13 pm »
Thank you for the quick reply going to order these asap
Offline Martk19871
  • Va Va Voom
« Reply #22 on: August 15, 2016, 10:31:19 pm »
Sorry for kick starting an old thread. Bit what ducting did people use for this model? Where from? Thanks
Offline bad devotions
  • -Given: 19
« Reply #23 on: August 16, 2016, 10:09:21 am »
i should imagine that you can pick up that sort of piping from B&Q and the likes. Good find though. I quite like this mod, although am not running a CAI just yet.
Offline Dan648v
  • -Given: 28
« Reply #24 on: August 16, 2016, 11:08:08 am »
I got mine from just searching eBay for air ducting, quite abit comes up  :happy2:
Offline Martk19871
  • Va Va Voom
« Reply #25 on: August 16, 2016, 06:15:19 pm »
Reason I asked is I've been to B&Q and Homebase, literally nothing that will work, looked for ducting / pipework in electrical and plumbing.
Ok cheers Dan, I will just take a chance on something off ebay, hopefully it's not too wide etc.
« Reply #26 on: August 17, 2016, 11:34:26 am »
Get some ducting from ebay. I used RAM AIR ducting 100mm x 1000mm. I also used a air funnel (see build thread), also ebay and same size or VERY close in size will be fine.
Remove fog light to allow access and slightly squash tubing to fit....job done.
Offline Martk19871
  • Va Va Voom
« Reply #27 on: August 17, 2016, 10:01:34 pm »
Thanks man, that's pretty much what I've ordered. I went with the 80mm x 500mm, hopefully it's just about long enough!
Offline Martk19871
  • Va Va Voom
« Reply #28 on: August 18, 2016, 09:56:36 pm »
Quick Thursday evening mod. Just about long enough. Went for a spin and I actually think it helps the Revo CAI breath hidden behind the front light.
Offline graham-gti
« Reply #29 on: August 28, 2016, 09:43:02 am »
Done his mod last night. Very easy to do :)
