Author Topic: MEGA- Mk6 Candy White GTi, Stage 3 K04, Brembos, BBS, Coilovers  (Read 72399 times)
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
Re: Got a Golf eventually... Mk6 Candy White GTi
« Reply #75 on: August 25, 2015, 10:06:29 pm »
Like! Much better now.  :happy2:
Offline Gaz
« Reply #76 on: August 26, 2015, 11:15:46 pm »
Thanks, Silver is growing on me. Looks clean!
Offline shaunnorris7
  • -Given: 18
  • 2008 GT TDI
« Reply #77 on: August 26, 2015, 11:43:26 pm »
That looks the nuts  :congrats:
Offline Gaz
« Reply #78 on: August 27, 2015, 10:13:06 pm »
Thanks mate. :)
Offline Moe
« Reply #79 on: August 28, 2015, 07:07:16 am »
Looks good mate, need to get one of these next
Offline Gaz
« Reply #80 on: August 30, 2015, 09:42:37 pm »
Someone mentioned port-matching the K04, so although it will likely make little/ no difference- i done it anyway since it was off.
Unitronic diverter valve relocation kit arrived from US so fitted that and the Forge boost pipes so its ready for the K04 to be fitted.
Pancake pipes look super restrictive compared to Forge pipes so im well happy i changed them, and im sure it goes a bit better now too. Hopefully help a lot when its running more boost with K04.
Changed the oil and filter again, another VW filter and some Gulf VW spec oil.
Offline chrisr763
  • -Receive: 62
« Reply #81 on: August 31, 2015, 07:02:18 pm »
CK's look sweet! Glad you finally got a set!  :happy2:
dansmith180
« Reply #82 on: August 31, 2015, 07:16:25 pm »
Looking really good mate  :happy2:
Offline Gaz
« Reply #83 on: August 31, 2015, 07:40:09 pm »
Thanks chaps. Yous not like my new boost pipes too? Lol!
Offline Gaz
« Reply #84 on: September 03, 2015, 09:25:01 pm »
Had to change my tyres from the Goodyears back to the Falkens as the rim protector was so huge on the Goodyears that it fouled the rear arch very slightly when loaded up. Although both 225, the Goodyear was 10mm wider! How stupid.
Goodyear:
Falken
Ordered a Helix Organic clutch today, hopefully be here in a week or so..
« Last Edit: September 03, 2015, 09:27:08 pm by Gaz »
  • -Given: 18
  • 2008 GT TDI
« Reply #85 on: September 03, 2015, 10:36:36 pm »
How do you rate the Falkenham? I need to get a new set soon and can't make up my mind. I think they definitely look better with less of a rim protector.
Offline Gaz
« Reply #86 on: September 03, 2015, 10:46:05 pm »
Not even driven it since i put the Falkens on !
They do look miles better though.
Offline jaffa
  • -Receive: 44
« Reply #87 on: September 04, 2015, 06:15:02 pm »
Falkens are pretty good tyres IMO they don't have the grip of Goodyear or Michelin etc but they are still pretty good
I don't buy them for the performance tho I buy them for the way they stretch so if you like to push your car then get a get something better
Love how the car is coming along Gaz makes me want to get some 19's now!
« Last Edit: September 05, 2015, 05:43:44 pm by jaffa »
Offline Gaz
« Reply #88 on: September 13, 2015, 10:22:52 pm »
Fitted a Forge catch can/ PCV delete kit as the PCV is bad for failing and causing trouble.
Gained a hesitation at 2500rpm and sourced it to a bad connection and a spark plug/ coil.
2 of the old plugs, clear to see the dodgy one!
New uprated NGK Double Iridium plugs as specified by APR for stage 3 K04
Eventually got round to fitting the K04 :D
Thankfully my modified compressor outlet pipe is PERFECT! Length and angle is spot on, Thank fck. Made making up a boost pipe between turbo and Forge outlet pipe easy!
Now up and running and i need to get an APR stage 3 map on it ASAP!
Offline Gaz
« Reply #89 on: September 14, 2015, 06:27:57 pm »
Fitted R8 coilpacks after having issue with bad connection at plugs/ coils.
Hopefully eventually get the Helix clutch from @vrsalex AKS tomorrow as promised so i can fit tomorrow night as im booked in to get APR stage 3 software put on at the end of the week. :D
« Last Edit: September 14, 2015, 06:29:39 pm by Gaz »
