Author Topic: How to fit G65 sensor?  (Read 21146 times)
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« on: May 09, 2016, 12:44:55 pm »
Has anyone fitted a G65 sensor
Part number 1K0-959-126-A
Re: How to fit G65 sensor?
« Reply #1 on: May 09, 2016, 12:52:19 pm »
Youll need a crows foot spanner.
« Reply #2 on: May 09, 2016, 12:53:36 pm »
Something like these that you can put on a 3/8" extension.
Obviously youll need metric ones.
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #3 on: May 09, 2016, 01:48:02 pm »
Thanks @rich83
Location wise, don't suppose you could tell me the general area. Can I inspect if before I get dismantling?
« Reply #4 on: May 09, 2016, 01:52:08 pm »
Ohh... its in front of the block between the block and the radiators.
Its in a vertical position with the electrical connector on top. Its a pig to get to.
« Last Edit: May 09, 2016, 01:54:45 pm by rich83 »
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #5 on: May 11, 2016, 02:14:14 pm »
@rich83 could you tell me, is this the G65 sensor highlighted by the red circle I've put in?
That doesn't look too difficult to change, just twist counterclockwise?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #6 on: May 11, 2016, 02:36:44 pm »
That is the G65 @lukemk5gti
You will require a 17mm crows foot or something you can get down there with enough room to lever it. It's very tight down there let me tell you so better to buy the right tool for the job with a long 3/8 drive extension bar and rachet.
Hope that helps.
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #7 on: May 11, 2016, 02:56:24 pm »
Went out for another look there. So I actually need to get the crows foot down under to the bottom of the sensor to twist off!
I actually have a set of 90degree ratchet spanners at home so if it's of a decent length I'll do that!
Probably pick up the part from VW on Friday when I drop it in!
Thanks lads
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Last Edit: May 11, 2016, 03:17:13 pm by lukemk5gti »
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #9 on: May 11, 2016, 03:19:25 pm »
Right part no. buy it mate  :happy2:
« Last Edit: May 11, 2016, 07:26:41 pm by r5gtt »
« Reply #10 on: May 11, 2016, 05:47:13 pm »
Thats the f*cker
Offline Flyingscotsman
  • -Given: 26
« Reply #11 on: May 11, 2016, 05:52:55 pm »
you'll also need an o-ring seal - separate part number, not usually sold by e-bay sellers.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #12 on: May 11, 2016, 07:27:04 pm »
^^^ dealer job.
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #13 on: May 12, 2016, 08:08:28 am »
I could pick that up Friday.
Anybody able to help with a part number for that o-ring?
  • -Given: 26
« Reply #14 on: May 12, 2016, 08:18:10 am »
O-Ring:
Seal: 8E0 260 749 C - £0.77
