Author Topic: E30Dom's Edition 30  (Read 95863 times)
Offline E30Dom
  • -Given: 42
  • -Receive: 76
Re: E30Dom's Edition 30 - GAZ Coilovers on the Horizon...
« Reply #90 on: September 16, 2012, 06:10:47 pm »
Pics of the c*ap that came behind just the passengers front liner...
Diesel Daily Hack.
Offline E30Dom
  • -Given: 42
  • -Receive: 76
Re: E30Dom's Edition 30 - S3 Intercooler Install
« Reply #91 on: October 06, 2012, 09:59:56 pm »
OK today I have installed and S3 alloy intercooler, so I can go Stage 2+...
The APR guide is invaluable, just a few things;
The bottom screws for the grill are T20 not T25...
Think atep 19, the screws are T30 not T25...
Bag and label all screws, this is the best way to keep track...
Make sure the two prongs sit in the grommets and the top/side mounts slot in the cage and screws go in ok
The GTi hoses are easily modified with a hacksaw blade, cut in 3 places and bend back, take care so not to cut the rubber surface, if holding in a vice and cutting at the top, the alloy will split before going in to the rubber if you cut evenly...
Clean or replace the seal for the connector into the discharge pipe.
The inlet pipe hose goes straight on if you modify the pipes the way i did...
The discharge pipe hose needs to be trimmed to get the angle right, about 5mm off one side...
Found the slightest trace of oil in the hoses, but believe this is normal - as the lowest point off the system and oil vapours being drawn through it collects here.
Take your time, be methodical, tick off each step as you go, and note the APR is not so detailed on the refit stage.
The connectore plugs are easier to remove if you push them on first before pressed the clip.
This is a manageable one man job... I have proven that.
Some pics from the install...
Saftey first, car jacked up...
All apart... what have I done!?
Difference in coolers...
Carefully in place...
Front end ready to go back on...
Followed the APR guide but still numbered and labelled every set of nuts/screws...
MOdifying the pipework...
Pipes ready to go back on...
Hoses all clamped up...
All back together... *PHEW*
Hope it was all worth it when I go stage 2+, uploaded setting and sure it's more responsive and pulls harder already...
« Last Edit: October 07, 2012, 09:08:43 am by E30Dom »
Diesel Daily Hack.
Offline vRSAlex
  • -Receive: 253
« Reply #92 on: October 06, 2012, 10:23:30 pm »
All looking good mate.  Good fun fitting the coolers.  I personally would swap out those hose clips for some stainless jcs high grips.  The t bolt style ones can leak boost easily and clamp unevenly.
Your going to love stage 2+.  :happy2:
Follow AKS tuning on Facebook
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #93 on: October 06, 2012, 10:32:54 pm »
Oh don;t tell me that, I don't wann be weilding spanners again anytime soon... they are donw up pretty tight, felt solid. Wanna replace the seal on the inlet pipe as only cleaned it all up, so might do this at the same time... do you stock the right clips?
Cheers, can;t wait....
Dom
p.s. BIg thanks to TFSiMike for the support at gone midnight this morning.. lol
« Last Edit: October 06, 2012, 10:37:47 pm by E30Dom »
Diesel Daily Hack.
« Reply #94 on: October 07, 2012, 01:00:40 am »
Why did you not just buy the s3 pipes ? That's what I did
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #95 on: October 07, 2012, 06:59:46 am »
Cos I'm a cheapskate, lol.... Na cos I wanna go with the SFS hose set up at some point and thought pointless spending out £100odd quid on the S3 ones when with a simple mod, the gti ones fit perfectly...
Diesel Daily Hack.
Re: E30Dom's Edition 30 - One man Intercooler Install DONE
« Reply #96 on: October 07, 2012, 08:02:25 pm »
Great work Dom  :congrats:
Where did u get the IC? Looks lurvley  :drool:
Stage2+  :driver:
« Reply #97 on: October 07, 2012, 08:56:07 pm »
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #98 on: October 07, 2012, 09:00:01 pm »
Got the intercooler from Darkside Developments, and they supplied all the right bolts and clamps too...
Diesel Daily Hack.
« Reply #99 on: October 07, 2012, 09:24:30 pm »
S3 cooler is a worthwhile upgrade.  :happy2:
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #100 on: October 07, 2012, 09:43:45 pm »
Thanks buddy, I think so...
Diesel Daily Hack.
« Reply #101 on: October 07, 2012, 09:48:33 pm »
You should have left the air cone condenser off  :P
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #102 on: October 07, 2012, 09:55:55 pm »
Haha, I would have had to have got the system bled properly first, very rarely do i use my a/c anyway...
Does it make much difference though it hardly restricts...
Diesel Daily Hack.
« Reply #103 on: October 07, 2012, 10:02:32 pm »
At least 5hp gain and 10degreeC lower AITs*
*(Figures may be made up)
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #104 on: October 07, 2012, 10:16:50 pm »
Lmao... I was gonna fit the old cooler like a twitter cooler setup too...
Diesel Daily Hack.
